1614 wiring
5 replies to this topic
#1 32spec OFFLINE
32spec
  • 22 Thanks
  • 24 posts
Posted July 29, 2016 - 02:30 PM
I have a 1973 1614 pk that I recently overhauled the engine. On the trigger module by the flywheel, where does the terminal marked "I" go? Thanks, Jeff
  • fernandofr4 said thank you
#2 bill3t OFFLINE
bill3t
  • 44 Thanks
  • 77 posts
Posted July 29, 2016 - 03:31 PM
back to the expensive ignition i think.
  • 32spec said thank you
#3 32spec OFFLINE
32spec
  • 22 Thanks
  • 24 posts
Posted July 29, 2016 - 03:58 PM
Back to the ignition coil or switch? If coil, which side?
Thanks, Jeff
#4 32spec OFFLINE
32spec
  • 22 Thanks
  • 24 posts
Posted July 29, 2016 - 07:50 PM
Another question. This tractor has a breaker point ignition, so is this trigger module even needed?
#5 MNGB ONLINE
MNGB
  • 1,081 Thanks
  • 873 posts
Posted July 29, 2016 - 07:58 PM
No if you have points the engine must have been converted and the trigger is no longer needed.
#6 32spec OFFLINE
32spec
  • 22 Thanks
  • 24 posts
Posted July 31, 2016 - 06:31 PM
Thanks for the responses. Ignored that wire from trigger and it fired up beautifully. Hopefully will get another 40 years out of it
