MONTGOMERY WARDS 16 HP TRACTOR gear box
6 replies to this topic
#1 Xrperry ONLINE
Xrperry
  • 1,022 Thanks
  • 762 posts
Posted July 28, 2016 - 05:01 PM
anybody know the best grease to put in the right angle gearbox?
#2 chieffan OFFLINE
  • 10,088 Thanks
  • 6,612 posts
Posted July 28, 2016 - 07:54 PM
I would use 80 Weight or 80-90 Weight gear oil.
  • Xrperry said thank you
#3 Sprint 6 OFFLINE
Sprint 6
  • 236 Thanks
  • 296 posts
Posted July 28, 2016 - 09:51 PM
You can't use gear oil in it because it does not have a check or fill plug.  Originally, my manual states to pack it with 4 ounces of wheel bearing grease.  I filled mine half full of John Deere cornhead grease.  It is a flowing grease, 00 I believe.
  • Alc and Xrperry have said thanks
#4 Xrperry ONLINE
Xrperry
  • 1,022 Thanks
  • 762 posts
Posted July 28, 2016 - 10:24 PM
there was a lot of gear noise so i pulled the thing off, it had some thin grease in it, looked black and old.the gears all looked good,bearings felt good. cannot figure out the gear whine, its pretty loud.when you push the input shaft in and turn it you get a little noise, then you pull on it and turn no noise. there is only a small amount of end play. any ideas? also i cleaned it out, so i can tell its actually gear noise not bearings
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted July 29, 2016 - 07:30 AM
Lucas HD bearing grease
#6 Sprint 6 OFFLINE
Sprint 6
  • 236 Thanks
  • 296 posts
Posted July 29, 2016 - 05:01 PM
Those gear boxes are noisy as heck, they are straight cut miter gears.  Mine are quieter after the corn head grease.
#7 Xrperry ONLINE
Xrperry
  • 1,022 Thanks
  • 762 posts
Posted August 01, 2016 - 06:13 PM
well i packed it with grease, i couldnt find any bad parts when i had it cleaned.gears looked good, i fired it up and 75% of the noise was gone. the grease that came out of it  was real thin, almost poured out.
