bolens 853 throttle linkage help.
#1
OFFLINE
Posted July 28, 2016 - 04:42 PM
But now I have the carb bolted on I have forgotten how to connect up all the linkages e.t.c to the carb! Oooops.
Does anyone have any pictures of there own or diagrams?
Thanks matt
#2
ONLINE
Posted July 28, 2016 - 06:01 PM
- madmatt01 said thank you
#3
OFFLINE
Posted July 28, 2016 - 09:43 PM
Which engine model is that? I was just fussing with the B&S 170401 in my 750.
I recommend taking pics as you dismantle, makes reassembly much easier..not that it helps now.
Edited by dtsh, July 28, 2016 - 09:48 PM.
- Bolens800uk said thank you
#4
OFFLINE
Posted July 29, 2016 - 01:37 AM
Engine is 8.5 190401
#5
OFFLINE
Posted July 29, 2016 - 01:53 AM
I think what has confused me is the previous owner has the throttle cable coming in from the right... and it was making it all work backwards.. will have a tinker tonight
#6
OFFLINE
#7
OFFLINE
Posted August 02, 2016 - 02:39 PM
Can't seem to join everything up to make it all work the correct way... it will all work backwards though haha!
#8
OFFLINE
Posted August 02, 2016 - 04:05 PM
On the 170401, you pretty much have to remove the carb to hook or unhook the linkage and that one looks much the same.
#9
OFFLINE
Posted August 03, 2016 - 04:52 PM
#10
OFFLINE
Posted August 03, 2016 - 07:07 PM
I don't have any good pictures, but Sections 3, 4, and 5 of the service manual should be of assistance.
In case you do not have one, I believe this link goes to the correct manual..
https://www.scribd.c...iggs-Stratton-1
#11
OFFLINE
Posted August 04, 2016 - 10:52 AM
Still struggling with this!
My pictures show which holes the choke and throttle go into. I did not remove any springs on mine when I removed the cables from the tractor. What exactly are your struggling with?
