Kohler K321 head stud
5 replies to this topic
#1 twostacks OFFLINE
twostacks
  • 479 Thanks
  • 438 posts
Posted July 28, 2016 - 03:54 PM
I seem to have broken the head stud off just above the jam nut on my 1450 Cub Cadet. The muffler rotted and broke loose from the exhaust pipe and it broke the stud. My question is, can I remove the stud and install the new stud and torque it to specs or should I loosen all of the head bolts and retorque them all when installing the stud. The jam nut is still tight on the broken stud and the head gasket isn't leaking.
  • ruthievx60 said thank you
#2 KennyP ONLINE
  • 38,473 Thanks
  • 45,969 posts
Posted July 28, 2016 - 04:06 PM
I would think you could change the one without an issue. Just be sure to check it again after some run time.
  • twostacks said thank you
#3 grattone OFFLINE
grattone
  • 309 Thanks
  • 220 posts
Posted July 28, 2016 - 08:08 PM
IF it were me, I wouldn't run it until I replaced the head bolt and torqued it, then run it for a little bit and redo the torque as stated before. I would also have a new head gasket on hand incase that didn't last.
#4 twostacks OFFLINE
twostacks
  • 479 Thanks
  • 438 posts
Posted July 29, 2016 - 07:13 PM
Thanks fellas. I'll throw the new stud in with the proper torque and see what it does. Since the gasket wasn't leaking I figured that it might be ok, but I wanted a second opinion. Thanks again.
  • olcowhand said thank you
#5 olcowhand ONLINE
  • 41,250 Thanks
  • 31,443 posts
Posted July 29, 2016 - 07:46 PM
You should be fine.
#6 Helganazy OFFLINE
Helganazy
  • Banned
  • 5 posts
Posted August 24, 2016 - 04:29 PM
I am glad that Hotsoup brought this to light. Now as mgps13 mentioned, what would be the proper procedure to replace the washers without compromising a good head gasket seal or the integrity of your head. Could you just replace and re-tighten each stud at a time?
