Sears LT 8 36" Lawn Tractor Need Info
17 replies to this topic
#1 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted July 28, 2016 - 01:08 PM
I recently bought a Sears LT8 maybe a 1978-80 ? maybe built by Roper for Sears has a 36" deck 3 forward and 1 reverse gears 8hp Tecumseh engineIMG_20160713_190042.jpg IMG_20160713_190116.jpg IMG_20160713_190130.jpg Shifter Plate.jpg IMG_20160713_190055.jpg the #'s on the mower are gone as far as model and serial # sticker or plate. I have searched high and low for any information or owners manual its like a LT 8 does not exist without the model and serial #'s I have found engine parts that's no problem I know l don't  have the only one cause l seen 1 photo of another one. what l need is someone that has a LT8 could possibly pass on some information l am enclosing some photos of my mower thanks for any help
#2 MH81 OFFLINE
Posted July 28, 2016 - 01:34 PM
As far as I know, that unit was made by someone other than Roper.
Pretty sure they were made by Murray.
Might try 917.25700?
Not exactly it, but it's getting close.
#3 KennyP ONLINE
  • 38,393 Thanks
  • 45,939 posts
Posted July 28, 2016 - 01:40 PM
:wave: Welcome to the forum!
I just found an LT8 manual, but it's for a Roper and does not look like this one. I'll snoop some more.
#4 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted July 28, 2016 - 01:46 PM
Thanks for your help I will try that model #
#5 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted July 28, 2016 - 01:52 PM
I appreciate your help
#6 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,008 Thanks
  • 4,414 posts
Posted July 28, 2016 - 02:27 PM
Engine should be model 413-286142 Tecumseh.
Tractor Model may be 502.xxxxx something
Look at the diagrams here and see if model 917.255120 looks close. http://www.searspart...47/1509200.html
Also Google Sears LT8 36, there are a couple you Tubes that may shed some light.
  • MH81 and EricFromPa have said thanks
#7 EricFromPa OFFLINE
EricFromPa
  • 3,663 Thanks
  • 3,115 posts
Posted July 28, 2016 - 02:47 PM
Sears 197255120
Tecumseh VM80 8hp 4 speed
I had a LT10/36 mower like that years ago.Never liked it.Really slow,didn't cut very well and mine had ISO mounted engine with rubber mounts.It always threw and chewed up belts under load till I replaced the rubber mounts with steel spacers.Your correct on the year it's between 78-80.
hehe that's it larrybl  was typing this out while looking for the correct manual.Not much info on them on the web.
They made a veridrive version with the same transaxle and same engine and a tecumseh powered 10/36 and a Briggs powered 11/36.
Edited by EricFromPa, July 28, 2016 - 04:24 PM.
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted July 28, 2016 - 03:10 PM
:welcometogttalk:
  • oldcuz said thank you
#9 Tecumseh power OFFLINE
Tecumseh power
  • 1,478 Thanks
  • 1,113 posts
Posted July 28, 2016 - 03:46 PM
Murray built
#10 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted July 28, 2016 - 03:53 PM
That's a good # 917.255120 the grill in the diagram looks just like mine Engine #'s 143 296032  /  8311D
Thank you for helping
  • larrybl said thank you
#11 boyscout862 ONLINE
  • 12,861 Thanks
  • 9,174 posts
Posted July 28, 2016 - 03:58 PM
Welcome to GTT.  I have a similar one out in the woods. I'll check this weekend if there are numbers on it. Good Luck, Rick
#12 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Sears 197255120
#'s are good, is a rubber mounted motor
#13 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,008 Thanks
  • 4,414 posts
Posted July 28, 2016 - 04:00 PM
Not a problem, and Welcome :wave:
#14 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted July 28, 2016 - 04:43 PM
I recently bought a Sears LT8 maybe a 1978-80 ? maybe built by Roper for Sears has a 36" deck 3 forward and 1 reverse gears 8hp Tecumseh engineattachicon.gifIMG_20160713_190042.jpgattachicon.gifIMG_20160713_190116.jpgattachicon.gifIMG_20160713_190130.jpgattachicon.gifShifter Plate.jpgattachicon.gifIMG_20160713_190055.jpg the #'s on the mower are gone as far as model and serial # sticker or plate. I have searched high and low for any information or owners manual its like a LT 8 does not exist without the model and serial #'s I have found engine parts that's no problem I know l don't  have the only one cause l seen 1 photo of another one. what l need is someone that has a LT8 could possibly pass on some information l am enclosing some photos of my mower thanks for any help
I would like to thank everyone for all the information they have offered and for welcoming me to GTtalk its a great site.
#15 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted July 28, 2016 - 04:46 PM
I do need a shifter plate that I guess shows the shift pattern ? it just goes around the shifter.
