1967 jacobson cheif 800
8 replies to this topic
#1 jayreynolds13 OFFLINE
jayreynolds13
  • 3 Thanks
  • 5 posts
Posted July 27, 2016 - 09:28 PM
Hello everyone, im looking at getting a 1967 jacobson cheif that runs and drives, however it only goes into 1st and reverse, and when it neutral it can run and not move, but the rear tires are locked, is this a comon problem?
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,191 Thanks
  • 5,786 posts
Posted July 28, 2016 - 07:38 AM
:welcometogttalk: :camera: :camera:
#3 John Arsenault ONLINE
John Arsenault
  • 1,483 Thanks
  • 810 posts
Posted July 28, 2016 - 08:13 AM
With transmission issues there are so many things that can go wrong its hard to tell with out taking it apart and inspecting it. It can be anything from a cir clip that shifted, to a key that sheared , a broken gear , or bent shift dog.
#4 boyscout862 ONLINE
  • 11,483 Thanks
  • 8,484 posts
Posted July 28, 2016 - 08:48 AM
Welcome to GTT. Look in our Manuals Section for the transmission manual for that Jake. In the manual should be a "Troubleshooting Guide". It will help you to figure out the possible problems. Tranny problems greatly decrease the value of a tractor. Good Luck, Rick
#5 EricFromPa ONLINE
EricFromPa
  • 3,111 Thanks
  • 2,818 posts
Posted July 28, 2016 - 02:07 PM
Take your shifter off and make sure it's not stuck in gear.While in Neutral the forks will be lined up and look like a Slot.Thinking 1 of the forks may have come apart or someone had the shifter off and put it back in while it was in 2nd or 3rd gear.Or someone jammed it in gear and snapped the shift fork off.
Should look like this if it's in neutral.
I happen to have a 3 speed here on a parts tractor that had a blown out differential and worn out input shaft bearings and shift detent ball springs are shot.It also leaks oil out of every seal but it should help you determine if your stuck in gear.
Here's a dirty pic for ya.It's not quite in neutral.Slot where the shifter sits should be straight up and down in neutral.
  • TomLGT195 and jayreynolds13 have said thanks
#6 jayreynolds13 OFFLINE
jayreynolds13
  • 3 Thanks
  • 5 posts
Posted July 28, 2016 - 04:11 PM
Thanks for the pic, i should pick it up this weekend, I was told it was opens up in working condition but when they put it back it wouldn't work, I'm guessing the sift fork isn't in correctly, I will update when I get it
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,191 Thanks
  • 5,786 posts
Posted July 29, 2016 - 11:44 AM
Grab it before it gets gone
#8 jayreynolds13 OFFLINE
jayreynolds13
  • 3 Thanks
  • 5 posts
Posted July 30, 2016 - 01:29 PM
I picked it up, looked up serial and it's a 1965, however it doesn't have the removable shifter, at transaxle does this have? It says jmc
Edited by jayreynolds13, July 31, 2016 - 10:41 PM.
#9 jayreynolds13 OFFLINE
jayreynolds13
  • 3 Thanks
  • 5 posts
Posted July 31, 2016 - 10:42 PM
Ended up being a seat pan bolt that was way to long, who woulda guesses, best part I found it by accident
