HF Tire changer
29 replies to this topic
#1 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted July 27, 2016 - 09:19 PM
Opinions on HF's tire changer, please.
Have to change out front, and rear tires on GT's. From the overall customer reviews it appears to have a few weak points i.e. breaker bar, floor mounts.
Problems experienced by members? Anyone successfully beefed it up?
  • CharlesDes said thank you
  • 14,730 Thanks
  • 15,470 posts
Posted July 27, 2016 - 09:25 PM
There are a few guys that have them and they have posted about in different places. Hopefully they will give you a heads up on this tool.
#3 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted July 27, 2016 - 09:32 PM
Well the tires / Rims we are talking about in a PM. The tires will be removed with a Saws all as all you need is the rims, I'll use a dermal with a cutoff wheel to remove the rest of the tire bead.
I struggle braking tires down. Have not found an "easy" solution. I have tried many recommendations with no luck.
#4 Brucepts OFFLINE
Brucepts
  • 178 Thanks
  • 54 posts
Posted July 27, 2016 - 09:51 PM
I have the HF floor mount unit and mount it on a skid when I use it, for the money you can't beat it! Yes, it's built cheap for $40 (think that was around what I paid with a coupon?) you can't change tires any easier cheaper. I swapped around 4 sets of turfs and bar treads in a short amount of time. Use a lube on the tires/rims to put the tires back on, I failed to do that and it went harder than it should have had I used lube.
I've not used the small bench top one for the fronts but plan on picking one up sometime for future use.
The one thing I found was the piece with the 4 legs that holds the rim down is cheap cheap cheap but it works, probably will need to make a new one at some point down the road with extended use
Edited by Brucepts, July 27, 2016 - 09:53 PM.
#5 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted July 27, 2016 - 10:41 PM
If you get the small one, get a bead breaker too, you will not be able to break them with the changer, the big ones have a built in bead breaker.
#6 KennyP ONLINE
  • 37,450 Thanks
  • 45,472 posts
Posted July 28, 2016 - 03:42 AM
I have the floor mount changer. I use it to break the bead on all tires, including the small ones. I made a holder for the small tires so I could change them out also.
#7 KC9KAS ONLINE
KC9KAS
  • 5,324 Thanks
  • 4,671 posts
Posted July 28, 2016 - 04:24 AM
I have the larger floor model  that came from GREG SMITH EQUIPMENT.
I have changed 10-20 tires and it works really good for the price.
The bead breaker did break, but I re-welded it and all is well again.
I don't like how it "clamps" the wheel in 3 places. I manage to spin the wheel right out of the clamps.
All in all it was well worth the money
#8 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted July 28, 2016 - 05:38 AM
I found that you can't use the HF floor mount model to take off the tires from front rims I brought it back how many tire changers am I going to have ?
  • Phluphy said thank you
#9 KennyP ONLINE
  • 37,450 Thanks
  • 45,472 posts
Posted July 28, 2016 - 05:52 AM
I have the two!
#10 MH81 OFFLINE
Posted July 28, 2016 - 06:29 AM
So far, I consider the bead breaker to be with the price. The holder and changer are ok. A few tires, I've done on it, a few the old fashioned way.
I'm serious when I say the bead breaker is worth the expense. I don't mind doing a tire with a set of bars, usually... But the breakdown is what gets me. This saves me a ton of aggravation and work.
Haven't figured out where I want it yet, so we've been clamping to this or that as a base.
  • KC9KAS said thank you
#11 chieffan ONLINE
  • 9,565 Thanks
  • 6,406 posts
Posted July 28, 2016 - 07:09 AM
Be better off watching auctions and sale listing and pick up a manual Coats changer.  I did several years ago for $100 and wouldn't trade it for a dozen HF changers.  Have to get inventive for the GT front wheel but it gets the job done.
#12 HDWildBill OFFLINE
  • 8,975 Thanks
Posted July 28, 2016 - 07:52 AM
I have the HF tire changer with MC adapter.  I ended up making my own base for the MC adapter and just use the bead breaker on the tire changer.  I use both on a regular basis for MC and tire changes.  Works great for me.
#13 boyscout862 ONLINE
  • 12,535 Thanks
  • 9,035 posts
Posted July 28, 2016 - 08:43 AM
Over thirty years ago I bought an old Bain Brothers tire changer for $25, it came with a 4' x 4' concrete slab under it. It sits outside with a 5 gallon bucket over it to protect the hold down threads. I have changed 100s of car and truck tires with it. The 12" GT tires are a little aukward but doable. Anything smaller won't fit. The little HF tire changer went on sale for $27 and I grabbed it. It took me a couple of weekes to figure out the best place to mount it. I mounted it horizontally on the end of a heavy steel work bench. When not in use, I pull the pin and just put most of it on the bench. This works pretty well but there still are times when busting a bead is difficult. A few years ago, I bought a very old mechanical car tire bead breaker for $10. It is a portable(20 lbs) tool that just sits on the floor. It is faster and stronger than the HF. It makes short work of any bead so that I save time and effort. The other alternative for bead breaking is a bead breaking hammer. I've busted many split rims with mine but I don't think anyone else uses them. You may be able to pick one up cheap. There was a GM coil spring compressor that worked for breaking small tire beads too. Lubricants will help alot when disassembling and assembling. Good Luck, Rick
  • Alc and Phluphy have said thanks
#14 Dugmf12 OFFLINE
Dugmf12
  • 88 Thanks
  • 60 posts
Posted July 28, 2016 - 09:14 AM
I have both, the small and floor mount.  It serves me fine, although I have only changed maybe a dozen tires with it.  I put floor anchors in garage for the large one and I place the small one in my vice I have on a work bench.  Serves me fine.  I use the floor mount to break beads on both the front and rear gt tires.  I am quite satisfied so far.  Use a soap solution to help with mounting, it's almost a must.
#15 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted July 28, 2016 - 11:27 AM
What was the major problem encountered with front rims? Without going out to check, I believe these are 8" rims.
