wheel horse RJ rear axle rebuild parts needed
5 replies to this topic
#1 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted July 27, 2016 - 07:21 PM
   I have been doing a little searching and figured I would just ask, I started working on my wheel horse rj again and need to replace the rear wheel axle seals and o course the bushings.  I can get a complete rebuild kit on flea-bay or $200 but before I spend the cash if someone here can get them for a little cheaper than that would be great.  any help would be appreciated.
        Pete
#2 Bolens 1000 OFFLINE
  • 15,287 Thanks
  • 18,233 posts
Posted July 27, 2016 - 07:23 PM
Let me know the part numbers if you can or model of the transmission and I'll see what i can do
  • johndeereelfman and petrj6 have said thanks
#3 HANKG OFFLINE
HANKG
  • 6,536 Thanks
  • 3,506 posts
Posted July 27, 2016 - 07:39 PM
Hi Pete, you can get the bearings bushings and oil seals thru napa should be cheaper.
#4 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted July 27, 2016 - 07:44 PM
Not trying to take business away from Brian (Bolens 1000) but I'd contact fellow member JakeKuhn (Jake). He has all of the parts you'll need, and is willing to give the advice should you get stuck. I just received my box from him that contained all of the bearings, seals, gaskets, and axle bushings. Very pleased with the parts, and he is a super great guy to do business with. I highly recommend him. Just send him a PM.
Edited by johndeereelfman, July 27, 2016 - 07:46 PM.
  • boyscout862, JakeKuhn, HANKG and 2 others have said thanks
#5 GWest OFFLINE
GWest
  • 553 Thanks
  • 504 posts
Posted July 28, 2016 - 04:36 AM
As far as I know the rear axle seals 1257 replaced by 83-2840 are available from Toro only.
All the seal companies have a replacement using their interchange but they won't fit.
Reason being in this application the seal is installed over the axle tube like a cap.
Most seals install into a counter-bore but this is different.
Garry
  • boyscout862 and MolonLabe have said thanks
#6 Racinbob OFFLINE
Racinbob
  • 76 Thanks
  • 68 posts
Posted July 30, 2016 - 06:20 AM
http://www.partstree...rchTerm=83-2840
These seals are on and off as far as availability. Toro said not available a short time ago but so did Partstree at that time. Now it looks like Partstree has them again. I didn't check Toro this morning.
