Cub 782 and 1811 similiarites and differences
cub cadet 782 1811
19 replies to this topic
#16 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted July 26, 2016 - 05:44 PM
  :thumbs: :thumbs: :thumbs: glad you "caved"  I haven't seen any back here for that kinda $, nor do they look that good !
  • BNK and Mark 149 J. have said thanks
#17 olds45512 ONLINE
olds45512
  • 1,502 Thanks
  • 740 posts
Posted July 26, 2016 - 05:48 PM
Near the front my bet would be the filter or the cork gasket between the pump and the transaxle housing. Neither are expensive, but the gasket is an involved process. Could also be on of the hystat tubing lines.
Could also be one of the relief valves on the top of the trans.
Edited by olds45512, July 26, 2016 - 05:49 PM.
  • IHCubGuy and Mark 149 J. have said thanks
#18 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,909 Thanks
  • 1,617 posts
Posted July 27, 2016 - 12:50 PM
Said news today.  The owner sold the tractor to someone else even though he said it was mine.  I wasn't able to get the money to him before someone else showed up.  I'm bummed out but there's not much I can do.  Such if life sometimes.  I'll continue my search for a 782 or 1811.
  • ducky said thank you
#19 olds45512 ONLINE
olds45512
  • 1,502 Thanks
  • 740 posts
Posted July 27, 2016 - 01:28 PM
That suck, you should go kick that guy in the balls. If you find a 782 make sure it has the series 2 engine in it, the series 1 wasn't pressure lubed and the motor will blow if you run it on a hill.
  • Mark 149 J. said thank you
#20 aagitch OFFLINE
aagitch
  • 107 Thanks
  • 83 posts
Posted July 29, 2016 - 06:05 PM
Early 782's were IH built. Even some of the first MTD owned/built 782's had black cast rears. They continued to use what IH had leftover from their inventory. An 1811 is virtually a 782 with an aluminum rear and better motor. Can't go wrong with an 1811
  • jpackard56 and Mark 149 J. have said thanks
Also tagged with one or more of these keywords: cub, cadet, 782, 1811
