How to remove a rusty steering wheel without a torch
6 replies to this topic
#1 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted July 25, 2016 - 07:12 PM
Hope this is posted in the correct section?
This works on other rusty parts as well.
Cheers.https://youtu.be/VjzjdeaJb8U
  • ducky, Gtractor, Alc and 5 others have said thanks
#2 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted July 25, 2016 - 10:30 PM
Also a good way to shrink bearing races to get them out of blind holes
  • Texas Deere and Horse and Bmerf have said thanks
#3 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted July 25, 2016 - 10:35 PM
Muriatic Acid will eat All of the rust and won't touch the plastic or rubber or even the paint on it.All you have to do is find a way to submerge the wheel and column in it for 20-30 minutes.Then it will pull rite off without having to heat it at all.
  • ducky, Bruce Dorsi, KennyP and 1 other said thanks
#4 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted July 26, 2016 - 08:27 AM
I enjoyed the video right up until he installed the new wheel on the rusty shaft, without cleaning it or using anti-seize.
  • 29 Chev said thank you
#5 MiCarl ONLINE
MiCarl
  • 2,048 Thanks
  • 1,057 posts
Posted July 26, 2016 - 11:31 AM
No problem - he can just weld that one off too!
I wonder what else he broke beating on it with a hammer.  Seems like a puller would have been a more appropriate tool.
One thing he didn't point out is he attached the ground lead to the wheel rather than the steering shaft or the tractor chassis.  It needs to be done that way to eliminate the chance of welding the wheel to the shaft.
#6 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted July 26, 2016 - 12:55 PM
 And don't run a bead all the way around 'cause it'll make it tighter. Yes, a puller would have been my preferred tool.
                                                      Mike
Edited by ol' stonebreaker, July 26, 2016 - 12:56 PM.
#7 tater195 OFFLINE
tater195
  • 2,200 Thanks
  • 1,413 posts
Posted July 26, 2016 - 01:22 PM
You would think with all those fancy welders, he probably has a plasma cutter too. Even if he didnt, he could have used the stick welder for an air arc. I am better at burning stuff up with an arc welder than I am at welding with one.
