Loading atv tires for my s-16
8 replies to this topic
#1 Gillis.jim OFFLINE
Gillis.jim
  • 285 Thanks
  • 162 posts
Posted July 25, 2016 - 01:51 PM
Well I've been seeing lots of people using windshield wash fluid to load their garden tractor tires so I decided to give it a try. I will be needing the tractor to spread topsoil and level my sister and fiancé's new yard so I figured having a little extra weight on the drive wheels will be much better for traction and handling.
I used a fluid transfer pump that I received from a friend that works at the hospital. Not sure what it was used for but it works great for this!
It has a flow of 1.6gpm at 36 psi
I used 11 jugs of windshield wash PER TIRE.
I made up a little air chuck for the valve stem and voila! I was in business.
Took all of 20 minutes to fill and reinstall them on the tractor. Can't wait to see the difference in traction!
Edited by Gillis.jim, July 25, 2016 - 01:55 PM.
  • Wm McNett, KennyP, propane1 and 1 other said thanks
#2 shorty ONLINE
shorty
  • 5,291 Thanks
  • 5,171 posts
Posted July 25, 2016 - 02:05 PM
That will make a difference. Were you running atv tires before?
  • propane1 said thank you
#3 KennyP ONLINE
  • 37,582 Thanks
  • 45,541 posts
Posted July 25, 2016 - 02:24 PM
Should have gotten the scales from the bathroom and done a before and after weight. In your part of the earth, might want to keep them from freezing this winter! I'm good for -20° down here, not sure about your neck of the woods!
  • Wm McNett said thank you
#4 propane1 ONLINE
propane1
  • 8,482 Thanks
  • 4,041 posts
Posted July 25, 2016 - 08:54 PM
I filled my mower turf tires two weeks ago with 6 to 7 US gallons of water. Amazing difference in traction. Water was free, but have to drain them before it freezes. But it's only a mower so I don't need freeze protection.
Noel
#5 Gillis.jim OFFLINE
Gillis.jim
  • 285 Thanks
  • 162 posts
Posted July 25, 2016 - 09:57 PM
I hope so!
I run the atv tires in the summer and turfs with chains in the winter.
I'd like to get a set of rims for my other set of tires. Would make switching from winter to summer a lot easier!
  • shorty said thank you
#6 Gillis.jim OFFLINE
Gillis.jim
  • 285 Thanks
  • 162 posts
Posted July 25, 2016 - 10:01 PM
I used -35 wwf but we do get some cold snaps around -40 in the winters. Hopefully they don't freeze!
#7 Gillis.jim OFFLINE
Gillis.jim
  • 285 Thanks
  • 162 posts
Posted July 25, 2016 - 10:15 PM
Was able to get 80 lbs into each tire!
#8 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted July 30, 2016 - 10:08 AM
What size are your ATV tires?
#9 Gillis.jim OFFLINE
Gillis.jim
  • 285 Thanks
  • 162 posts
Posted July 31, 2016 - 12:17 PM
26 10 12
