speaking of projects...
roper 18t hydro
23 replies to this topic
#16 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,605 Thanks
  • 1,306 posts
Posted July 25, 2016 - 11:38 PM
I will try something different for the next pictures. For some reason it also takes 7-8 minutes to upload each picture from the phone. Hopefully the PC will be back up soon.
#17 MH81 OFFLINE
Posted July 26, 2016 - 06:21 AM
Tractor has to feel better with the pending heart transplant.
Just out of curiosity, why is the motor on sideways in the one pic?
  • rustyoldjunk said thank you
#18 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted July 26, 2016 - 06:52 AM
If it's not charging, pull that flywheel and check the magnets. With that muffler up there, could have loosened them!
#19 John Arsenault ONLINE
John Arsenault
  • 2,424 Thanks
  • 1,167 posts
Posted July 26, 2016 - 07:03 AM
A little progress this evening. The plan is to put the Tractor back into running condition and work out the bugs,then hopefully this winter take it apart for paint.
attachicon.gifpost-325-0-60330600-1469507565.jpg    attachicon.gifpost-325-0-34017500-1469507784.jpg
Looks like you have a leak from the rear end.....I think its a great idea to get it running first then tear it apart again. If I would not have done that with my hydro I would not have found a few issues until I got it running.
#20 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted July 27, 2016 - 02:24 PM
I decided to at least pull the tins and make sure the fins were clean and straighten up the head tins before I bolted the engine on the tractor.
#21 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted July 27, 2016 - 02:28 PM
It has at least two leaks that I have to iron out. Here is the thread to where I pulled the rearend and hydro out and completely were thru the hydro pump and drive motor last winter. The tractor had sat outside in a wet field for 15 years. The hydro was full of water and stuck. I know the input shaft seal on the pump is leaking and one metal line is leaking at a connection that I didn't get tight but I can't tighten it until I take the pump back out to replace the input shaft seal. It is tight under there ! http://gardentractor...per +18t +hydro
Edited by rustyoldjunk, July 27, 2016 - 02:32 PM.
#22 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted July 27, 2016 - 02:31 PM
I got the PC back up and going but now its been too long so I couldn't edit the original post to add a link to the original thread that I had on this tractor so its in my reply above. EDIT: You would think that by my age I would slow down and take a better look before I speak (or type). I just saw that MH not only fixed the pictures in my first post but looks like he added a link back to the thread. Thank you Alan.
Edited by rustyoldjunk, July 27, 2016 - 02:39 PM.
#23 MH81 OFFLINE
Posted July 27, 2016 - 06:12 PM
Kenny got the pics, I got the link.
#24 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted July 27, 2016 - 06:51 PM
Well in that case,thank you again Kenny :D
