Question about front tire sizes
7 replies to this topic
#1 GrantC OFFLINE
GrantC
  • 6 Thanks
  • 26 posts
Posted July 24, 2016 - 07:33 PM
Will the standard Bolens front wheels, which look to be the same on my 1220, G12, and H16, take tires as narrow as 4.8-8?
At the moment they all have 6.5-8, but both the G12 and H16 will need new tires once I get them running. (I've always liked the narrower front tires that the Simplicitys of the '60s wore.)
#2 stiemmy OFFLINE
stiemmy
  • 2541 Thanks
  • 1830 posts
Posted July 24, 2016 - 10:39 PM
Most tires are what they're designed for, please, see the manual section!
Cheers!
Edited by stiemmy, July 24, 2016 - 10:43 PM.
  • MailmAn said thank you
#3 chieffan OFFLINE
  • 16594 Thanks
  • 9088 posts
Posted July 25, 2016 - 07:00 AM
I think your rim is going to be to wide for those narrow tires.  Your talking about a wheel borrow tire on a GT.   Best to stay with what the machine was designed to have, unless you want to change rims and all to get some looks.
Edited by chieffan, July 25, 2016 - 07:01 AM.
#4 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted July 25, 2016 - 04:24 PM
I would suggest finding a suitable replacement rim if you want to narrow it up that much.
#5 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted July 26, 2016 - 05:07 AM
How about a set of tri-rib tires?
They will give the appearance of being narrower than they are.
  • jpackard56, Paulgo and GrantC have said thanks
#6 GrantC OFFLINE
GrantC
  • 6 Thanks
  • 26 posts
Posted July 26, 2016 - 11:25 AM
Not a bad idea.
I was a little unclear in my original query, because there is a functional reason I want those narrow knobby tires: their square shoulders have better resistance to side slippage. The wider, rounder ones are better for lawns but I don't care about that; I want them more resistant to slippage when turning on soft ground. The tri-rib would be a good solution — thanks for the suggestion!
Edited by GrantC, July 26, 2016 - 11:26 AM.
#7 GrantC OFFLINE
GrantC
  • 6 Thanks
  • 26 posts
Posted July 30, 2016 - 10:15 AM
YIKES! Boy, are those things expensive!
Anyone know if there are tri-ribs in 6.50-8 that don't cost $90 each??
#8 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted July 30, 2016 - 12:42 PM
I think Firestone is the only ones making the tri rib in a 16x6.50-8. Look into going V61's. Sold by Miller tire. I have them on my 420 and want to put a set on all my machines. Love them. They have 5 deep ribs on a wider tire that give little to no slippage
Edited by dropped82, July 30, 2016 - 12:43 PM.
