Wagon or Trailer project
20 replies to this topic
#16 Greasy6020 OFFLINE
Greasy6020
  • 1,473 Thanks
  • 1,397 posts
Posted August 13, 2016 - 08:46 AM
Update :
got a little done on it 20160809_195226.jpg am sorry it is a tadd off
got the 2 rear corner posts fitted and got the back boards cut & 1 side board there , the boards are not screwed in yet as i got to disassemble it to varnish when its done 20160809_195328.jpg
Shane
Sorry what's a tad off? Looks perfect to me!
My carpentry isn't the best... Or relatively near the best.
#17 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted August 21, 2016 - 12:40 AM
 Greasy , tad off = not quite perfect , but thank you ,as i'm pretty rough learning to use these wood work tools m8 but i'm getting the hang of it quick , pretty easy actually
  • MH81 and Greasy6020 have said thanks
#18 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted August 27, 2016 - 06:12 PM
UPDATE
slaving away on it still at night received_10154050415612763.jpg got
 all the sides on now looking a tadd better
 received_10154050416217763.jpg the seat is in , it was an after thought to have the seat fitted
got the foot rests done , i decided to anker them in with light chain for something different , but still looks good i think received_10154050939877763.jpg
received_10154050940622763.jpg ,
this is where i used the router Picture 470.jpg   only had to test runs 1st then did the wagon ,
so i'm slowly getting it done try i
to find old steel wheels off old wheel barrows and such to go on ot but not having much luck so might make some if need be
Shane
  • MH81, KennyP and CanadianHobbyFarmer have said thanks
#19 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted August 27, 2016 - 09:41 PM
I have 2   4 wheel wagons I built out of old lawn mower frames.  Plenty strong and have the steering on them already.  After 15 years the flat bed is starting to go on the one.
Do you have any pictures of how you set up the front tongue and steering??
I am anting to do the same thing with a JD316 frame I have.
#20 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted September 02, 2016 - 10:45 AM
update
i have finished the front axle  20160902_1811341.jpg  i made u bolts for the ends to support the steel axle fitted into the timber frame
 20160902_1812451.jpg & drilled the center of the axle and bolted it through the wood to stop the axle turning and moving ,
have to make the mounts to affix it to the turn table now
Shane
  • KennyP and CanadianHobbyFarmer have said thanks
#21 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted September 10, 2016 - 09:21 AM
UPDATE   repairs
its a bit hart finding some wheels the same and last week end i picked up an old wheel barrow in tatters just for the steel wheel on it 1473070034076.jpg this it after i trimmed 1" off 1 end and 1 1/2 off the other end 1473070044281.jpg
here is the wheel with a replacement piece of flat stock same size shaped to fit and welded back in
i have to grind the welds down nice yet but it turned out pretty even when i spun the wheel so now it gives me another wheel option
Shane
