i have wanted to make a little wagon type trailer 4 wheels like a old farm trailer for some time now so in the early part of the week started making 1 at night after dinner to make a start on it
this is the 2 x 1' chassis to start with pre made , was a treadmill exerciser base after most of the brackets were cut off
this next 1 is of the chassis and turntable mounted
and the rear axle mounting and some stabilizer chains fitted ( must have the chains under it to hold all the turn table & rear axle in place ) the whole undercarriage setup relies on the chains
overhead view of the turn table & chains setup
front view of the table & chains , the chain sitting there unattached will hook up to the pull pole as a imitation thing
with it in lifted up position
in down position , the turntable can go to about 30 deg up or down & turn 360 deg until i make stoppers for it
rear under view of it
the rear axle & wheels are not set to width yet , will be using 8" tires when it's done
a pic with the deck done
the side wall or( sides) are cut to 10deg out set like old wagons were in principal
i have to finish it before i disassemble to sand plane & varnish it so when i do i will post pic's of the turntable in bit's for ya'll, the turntable ring was off a dining table sauce & salt & pepper spinner thingy , post more later on it
Shane
