Need help with a gravely L8
6 replies to this topic
#1 Johnstp4 OFFLINE
Johnstp4
  • 2 posts
Posted July 23, 2016 - 05:01 PM
I am the proud new owner of a 1970 ish gravely L8 walk behind. I rebuilt the carb new head gasket and cleaned and set the gap on the points. It's a pull start so I put about a half gallon of fresh gas in it and tried to start it. After 3 good pulls it fired up and ran beutifuly. I turned it off and tried to start it back a minute or so latter. After 3 hours of pulling it still won't start. All it will do pop like it's going to start as long as I'm turning the crank but it won't start. I have electric blue spark at the plug and gas. Is it a mag problem or a carb or what? Any help will greatly appreciated.
#2 HDWildBill OFFLINE
  • 8,984 Thanks
Posted July 23, 2016 - 05:40 PM
Welcome to GTtalk. Have you checked to see if your getting gas to the cylinder?
#3 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted July 23, 2016 - 06:35 PM
If your spark is good, and not intermittent, you could probably rule that out. If it is intermittent, points and condensor are likey need replacing.
Once you are sure ING. components are working properly, tty puting a lil gas down the hole, and starting it. If it starts, Id say it is carb related, if it doesnt, I would look for a sticky valve, or run a compression test on it. Cheers
#4 Bolens 1000 ONLINE
  • 15,423 Thanks
  • 18,279 posts
Posted July 23, 2016 - 07:20 PM
If you know your getting gas, I suspect faulty condenser or breaker points
#5 DougT ONLINE
DougT
    Dog Approved
  • 7,112 Thanks
  • 5,077 posts
Posted July 23, 2016 - 07:27 PM
My rule of thumb on spark is that you need at least 5 times the plug gap outside the cylinder to be able to fire the plug against compression. If that passes, have you tried a new plug? I didn't see it mentioned.
  • Gtractor said thank you
#6 Johnstp4 OFFLINE
Johnstp4
  • 2 posts
Posted July 24, 2016 - 03:00 PM
Thank you all for the help. I have checked compression and it runing between 75 and 80 lbs. I thought about the fuel issue so I tried to pour a little gas down the cylinder and then try to start it with the same effect, only putters whyle I'm turning the fly wheel and then nothing. I'm going Tuesday to pick up new condinser and points as a gravely mechanic sed that may the issue.
#7 tiretrx OFFLINE
tiretrx
  • 2,273 Thanks
  • 1,227 posts
Posted July 25, 2016 - 07:39 AM
One simple check is after pulling six or eight times, and it doesn't start, pull the plug and see if it's wet with fuel or dry. Dry, no fuel. Wet, no spark. Not the end all, but a starting point. Good luck, keep us posted.
