67 custom 6
13 replies to this topic
#1 Countryboo ONLINE
Countryboo
  • 143 Thanks
  • 157 posts
Posted July 22, 2016 - 08:31 AM
i have a 67 custom 6 & I need a mowing deck for it. I've found one that is model # 917.252031 off of a suburban compact 7. Will this fit my tractor?
#2 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 22, 2016 - 08:37 AM
Yes, if you mean Sears Compact 7, which is the same as the Custom series --though some models came with a gearbox without high-low capabilities-- but be careful with those decks and mowing heavy grass.  The drive system is made up of two gearboxes, a splined shaft and two splined collars.  Those collars and shafts, especially at this age, are easily stripped. But, surprisingly enough, most of the parts are still available through Sears.
A Suburban deck will not fit.  Two different drive systems and a Custom deck will only have two blades.
Edited by Dane in PA, July 22, 2016 - 08:40 AM.
  • TomLGT195 said thank you
#3 Countryboo ONLINE
Countryboo
  • 143 Thanks
  • 157 posts
Posted July 22, 2016 - 09:22 AM
The deck that I'm looking at is off of a suburban compact. So I guess as long as it's a compact it'll work. Sorry I new to this & kinda confused. You said that a suburban Would not fit it. That is the model number on the deck. What about a ballpark price for a decent deck. 917.252031
#4 Countryboo ONLINE
Countryboo
  • 143 Thanks
  • 157 posts
Posted July 22, 2016 - 09:28 AM
I'm sorry the guy is saying it came off of a Suburban Compact 7. The model number on the deck is 917.252031. I've looked for a deck/rotary mower number for mine, but haven't had much luck. Any help would be appreciated.
#5 MH81 OFFLINE
Posted July 22, 2016 - 09:53 AM
It appears to be the right kind of deck for the Custom tractors.
Only confusion is the lift handle pictured... They were bolted to the tractor on the customs.
The drawing at Sears is really bad tho....
Bottom line, the custom decks were gear distributed, feed belt comes in vertically.
the suburban is belt distributed, feed belt comes in horizontally.
What's he asking? I would say if in the $100 ball park for a deck you need... It should be fine.
#6 Countryboo ONLINE
Countryboo
  • 143 Thanks
  • 157 posts
Posted July 22, 2016 - 11:03 AM
He has it on eBay. Buy it now for $175. Here is the link
Vintage Sears Suburban Compact 7 Mower Deck # 917.252031
On eBay, it has a vertical pulley on it. I'm thinking that it'll work from the pictures. Was thinking about starting out $75 to $100.
Thanks for all your help. I'm not going to mow with it really just want to have it with the tractor to restore them together. I have 3 other mowers that I cut with.
#7 TAHOE ONLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted July 22, 2016 - 11:26 AM
We know your knew, but you can't use "suburban" and "compact" in the same sentence to describe one tractor, it's either -or. While they share some of the same parts, the compact was more of Sears entry level garden tractor and the decks will not interchange as you may be finding out and the front implements for a suburban will not fit a custom/compact.
If the seller is using those words, he maybe not knowing himself or he is using them as tag words for searches
I would say maybe $100, but it depends on how bad you need/want it. Price is dependent on how much buyer will spend.
  • jimmy G said thank you
#8 Countryboo ONLINE
Countryboo
  • 143 Thanks
  • 157 posts
Posted July 22, 2016 - 11:54 AM
Thanks, that's how he is explaining it in the link that I posted earlier. I have found that the manual for that model number 917.252031 show a 38" rotary mower for custom tractors. I just didn't see a year on it. Mine is a 67 custom.
#9 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 22, 2016 - 01:30 PM
If it's a 38", then it's a deck for a Custom.
Suburban is a completely different line of tractors to the Custom/Compact series.
#10 MH81 OFFLINE
Posted July 22, 2016 - 10:00 PM
I forgot to ask, steel or magnesium deck?
#11 Countryboo ONLINE
Countryboo
  • 143 Thanks
  • 157 posts
Posted July 22, 2016 - 11:07 PM
From the looks of the picture it's steel. I have an email out to him with a few questions & that's one of them.
#12 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 23, 2016 - 07:32 AM
Could also be Aluminum.   :thumbs:
#13 Countryboo ONLINE
Countryboo
  • 143 Thanks
  • 157 posts
Posted July 23, 2016 - 09:34 AM
Looks like steel, but still haven't heard back from dude yet.
#14 Countryboo ONLINE
Countryboo
  • 143 Thanks
  • 157 posts
Posted July 25, 2016 - 09:47 PM
Still haven't heard back from the guy yet, still got my eye on it & just wanted to says Thanks for all Y'alls help. Hopefully he email back & it's fits, but until then. Thanks
