DB cultivator beam extensions
6 replies to this topic
#1 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted July 21, 2016 - 07:58 AM
Would the cultivator beam extensions be made of the same stock as the cultivator frame itself  ?   Or some special steel ?
#2 MH81 OFFLINE
  • 29,978 Thanks
Posted July 21, 2016 - 08:34 AM
This is a guess, but It would be thickness, if anything.
#3 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted July 21, 2016 - 04:32 PM
The ones I have look to be the same stock used for the frame. As simple as they made these tractors I wouldn't think they'd get to technical with using different types of steel. They probably tried to keep the cost down as much as possible too.
#4 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted July 21, 2016 - 08:46 PM
I have a frame that has a twist in it from a hard life that might be better used as beam extensions but wasn't sure
#5 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted July 21, 2016 - 09:10 PM
Here's a video showing the extensions I have.
#6 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted July 22, 2016 - 05:32 AM
I'll have to wait until I get home to watch your video , they have filters here at work the block a lot of things . Do you think the cultivator frame would work for the extension ?   Would you mind taking a few close-up of the extensions and how the tabs are welded at the attachment point ? Thanks Al
#7 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted July 22, 2016 - 09:03 PM
The video was just what I was hoping for.
