1984 Cub Cadet 782 help needed
5 replies to this topic
#1 Dayton_King OFFLINE
Dayton_King
  • 1,512 Thanks
  • 1,161 posts
Posted July 20, 2016 - 10:25 PM
Here is the story. I bought a 1811 that was repowered with a brand new m18 and had 27 hours on it. The tractor was rough. I bought a 782 in good shape and I swapped out engines. I put new tires, wheel weights, and bought a deck.
First time I went to mow and the pto gave out. So I bought a new xtreme pto. I got it installed and check my voltage at full throttle 13.67v. Which is good. I torqued the pto to 55 lbs. I burnished the clutch like told. I went to mow and it ran great. 5 min into it it started running rough. And died. Had to clean the carb. Once I got the carb clean it ran great. But now my pto won't stay engaged. If i hold it up it will stay on. Any ideas?
#2 diesel nut ONLINE
diesel nut
  • 767 Thanks
  • 460 posts
Posted July 20, 2016 - 11:02 PM
Bad switch or relay or a bad connection in the plug on either of them will do that. Or a bad ground on the clutch itself.  The original clutch bolted onto the engine and from your pictures it looks like the new clutch is a mag stop type and might not have a good enough ground.  Hope this helps.                                   Stewart
#3 aagitch OFFLINE
aagitch
  • 107 Thanks
  • 83 posts
Posted July 21, 2016 - 01:21 AM
That new clutch has its own ground wire so make sure it's grounded good. Like mentioned it could be a bad relay or connection somewhere
#4 Dayton_King OFFLINE
Dayton_King
  • 1,512 Thanks
  • 1,161 posts
Posted July 21, 2016 - 06:20 AM
It's grounded good. Is the relay the silver box on the side ?
#5 diesel nut ONLINE
diesel nut
  • 767 Thanks
  • 460 posts
Posted July 21, 2016 - 11:33 AM
Yes the relay is the silver box on the left side of the dash tower
#6 Dayton_King OFFLINE
Dayton_King
  • 1,512 Thanks
  • 1,161 posts
Posted July 21, 2016 - 07:07 PM
Started checking all the systems. It ended up being the reverse micro switch. First cub I ever got to run long enough to mow a yard lol. I have another week of fine tuning.
