Simplicity 7016H Sovereign and a 1690039 tiller. More numbers 17711, which think is the mount.
Tractor missing the lift link hitch. Might be 12989? Triangular metal with a tube that the tiller has a rod to stick into, and a rod accross the back to fit on the tractor hitch area. Might have a pix, sort of. Found a manual on epay, but pricey. Wasn't seeing one here, am I wrong??
It is run by a cable off the lift handle. I have a cable now running down to mower, is it the same one? Goes from handle to over the pulley on chassis and out the back to the lift part above. Same? or do I need diff there also?
Anyone have one here that would sell and ship? Can PM me with prices and such. I have the owner's manual and shows how to connect and have the belt route and some idler pulley stuff all figured out now. Had to remove, press and blast and lube one pulley pivot, all rusted tight, as usual on this project.
