jacobsen side panels
garden tractor jacobsen
16 replies to this topic
#1 case1man OFFLINE
case1man
  • 202 Thanks
  • 138 posts
Posted July 17, 2016 - 08:40 PM
Just bought a jake 1650 closed side with a tiller for some reason has half side panels look to be factory because it has mid mounts on tractor and no lower ones the standard panel . Has anyone else ran into this
  • milliebh3 said thank you
#2 boyscout862 OFFLINE
  • 13,449 Thanks
  • 9,394 posts
Posted July 17, 2016 - 09:29 PM
Can you post pics? Good Luck, Rick
  • case1man said thank you
#3 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted July 17, 2016 - 09:59 PM
My guess somebody cut them?
We want pics!
#4 Rock farmer ONLINE
Rock farmer
  • 1,245 Thanks
  • 1,248 posts
Posted July 18, 2016 - 02:26 AM
Yes I've seen that on a few Jacobsen's.
If I recall correctly, the government set noise level limits for garden tractors back in the seventies.
Jacobsen must have had over heating complaints. And, that was thier solution?
Joe
#5 KennyP OFFLINE
  • 40,232 Thanks
  • 46,811 posts
Posted July 18, 2016 - 04:00 AM
I'd like to see pics of these!
#6 case1man OFFLINE
case1man
  • 202 Thanks
  • 138 posts
Posted July 18, 2016 - 10:01 AM
some picsIMG_0227.JPG IMG_0225.JPG IMG_0228.JPG IMG_0224.JPG IMG_0226.JPG IMG_0224.JPG
#7 case1man OFFLINE
case1man
  • 202 Thanks
  • 138 posts
Posted July 18, 2016 - 10:04 AM
If someone cut them did areal good job. Both sides cut exactly alike no sharp edges ,mounts look factory spot welded. Look at pic #3 and you will see the middle vent hole is not cut out.
Edited by case1man, July 18, 2016 - 11:00 AM.
#8 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted July 18, 2016 - 12:23 PM
Thats strange, never seen one like that before!
Not saying that they don't exist, cause anything is possible. Thank you for sharing the pics.
I would think there would be some extra mounting points for the tabs to lock into somewhere on the rig? Definitely different!
Cheers!;)
#9 case1man OFFLINE
case1man
  • 202 Thanks
  • 138 posts
Posted July 18, 2016 - 12:39 PM
Has mounting points midway on tractor . No lower mounts at all not even the rear one that's welded to frame
#10 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted July 18, 2016 - 12:44 PM
Thats odd, and puzzling to me.
Maybe someone else here has seen this before?
#11 KennyP OFFLINE
  • 40,232 Thanks
  • 46,811 posts
Posted July 18, 2016 - 03:23 PM
Very odd! Thanks for sharing with us! I have never seen anything like that before!
#12 dualresponse1731 OFFLINE
dualresponse1731
  • 255 Thanks
  • 175 posts
Posted July 18, 2016 - 07:25 PM
Thanks for posting. Just thinking out loud- I wonder if it was a factory experiment if they just "clipped" the bottom of some existing full panels, and used the existing bottoms and  lower mounts "upside down" and crimped the lower free edge, and flipping the whole panel upside down. The bottom of the panel would now be the top.  It would make a good way to make use of existing inventory.
Do you have the pics of the mid mounts on the tractor for the lower mounts (if they exist?)
Edited by dualresponse1731, July 18, 2016 - 07:27 PM.
#13 case1man OFFLINE
case1man
  • 202 Thanks
  • 138 posts
Posted July 19, 2016 - 01:31 AM
more pics of mounts notice no lower mountIMG_0230.JPG IMG_0229.JPG second pic is mid mount just below gas tank
Edited by case1man, July 19, 2016 - 01:33 AM.
#14 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted July 21, 2016 - 01:26 PM
This was the way Jake did it back in the mid to late 80's before they discontinued the tube frame tractor. My dad had an 86? Jake 16 HP tractor and it had the half sides on it. Also had a spring in the toolbox for holding the seat up a little, and the seat switch in the toolbox as well, instead of in the seat cushion.
  • KennyP and case1man have said thanks
#15 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted July 21, 2016 - 02:20 PM
Yup, seen it, actually many of the newer Jake's had this. They made them into the 90's.
