Newbie with questions
12 replies to this topic
#1 Justpics OFFLINE
Justpics
  • 10 Thanks
  • 129 posts
Posted May 17, 2011 - 12:55 PM
I picked up a MF 12G while in Portland Or last weekend, was looking for a lawn mower to mow the lots next to my landladys house. paid 75.00 and drove it onto the pickup.
1. the key will not start it. have to jump across on the terminals.
2. when engaging the mow deck it has to be done slowly, tho dose seem better after greasing the bearing casings. it dose spin up better. but needs to be slow or the engine dies.
3. when the engine starts to die, depressing the clutch, and retarding the throttle will keep it running.
4. wont mow much or far with out the motor dieing.
I am new to this area, was glad to see that they are collectable and have a following. I had bought it because it was a good price and well built,, plan on using it in the garden also. can anyone help, guide me to resolve these issues. I do plan on tearing down and rebuilding/restore this winter
Garry
#2 caseguy OFFLINE
  • 1635 Thanks
  • 5600 posts
Posted May 17, 2011 - 03:52 PM
:wave: Justpics Welcome to GTTalk! I don't know much about the 12G Masseys, but there are a lot of folks on here who do and I'm sure that they'll be along shortly. From what I understand, the 12 G's are a superb machine, built to last with plenty of power and available attachments. I think you made a great deal for $75! Hope that you get it going soon!
#3 wvbuzzmaster OFFLINE
  • 4726 Thanks
  • 7423 posts
Posted May 17, 2011 - 04:09 PM
Sounds like money well spent, and I would look into cleaning the carb if it has sat for any length of time. And my recommendation to clean the carb of a running engine like yours is go to Walmart and buy "Gumout - Entire Fuel System Cleaner" and dump a little in the gas tank, it does wonders. I usually just let the tractor sit and idle for the first 15-20 minutes after dumping the Gumout in for the first time. If that doesn't fix it there are more solutions, just tougher.
#4 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted May 17, 2011 - 04:25 PM
justpics,:welcometogttalk:
Glad to have you with us.
#5 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted May 17, 2011 - 04:26 PM
:welcome: to GTTalk!
Yes, you got a good deal. Maybe better than good.
I do believe there are going to several minor maint. adjustments and possibly a carb rebuild in your future... but Casey has the best first step. Try some carb cleaners and also look around here a little bit to read up on the effects of ethanol in the new gas and also the benifits of SeaFoam for continued long term reduced troubles.
When you get the chance, there is a service manual that will be invaluable. It can be found in the manuals section under Massey Ferguson. Good luck with your new GT, and if you have pics, please post them.
#6 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1295 Thanks
  • 1443 posts
Posted May 17, 2011 - 05:15 PM
:welcometogttalk::tractor_rocks: They are a real nice machine, good tune up should get ya going, carb clean, sparkplug and filters. Shawn
#7 KennyP ONLINE
  • 53218 Thanks
  • 53323 posts
Posted May 17, 2011 - 05:42 PM
Justpics, welcome to the best forum going. I agree with all that has been said and hope your new tractor gives you many hours of service. There are lots of folks with knowledge of your 12G.
#8 Justpics OFFLINE
Justpics
  • 10 Thanks
  • 129 posts
Posted May 17, 2011 - 11:05 PM
Thanks for the welcome, and for the advice, I enjoy working on things so this will be fun. the local MF dealer was very helpful printed about 50 pages of part diagrams for free. was told to check the compression as if it is low that could be one of the problems. looks like the ignition switch is shot, so will replace that tomorrow.
pictures will be coming.
#9 wvbuzzmaster OFFLINE
  • 4726 Thanks
  • 7423 posts
Posted May 17, 2011 - 11:25 PM
Sounds great, good luck with it. I had a shot ignition switch on one of my tractors, still rewiring the whole tractor but that's a scope creep problem lol.
#10 daytime dave OFFLINE
  • 5494 Thanks
  • 6782 posts
Posted May 17, 2011 - 11:34 PM
Welcome Justpics. Glad you are here
#11 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted May 18, 2011 - 05:08 AM
Make sure you get the right Ign switch for it. You need a mag style, not powered. If you put the wrong one on, you could kill a very expensive part on the ignition system. May want to go back to the nice dealer for that one, unless someone here knows of a generic drop in?
:anyone:
#12 KIRO-1 OFFLINE
KIRO-1
  • 40 Thanks
  • 300 posts
Posted May 18, 2011 - 07:18 AM
Keep in mind that if you take a compression test using the plug hole the engine has a decompression valve that doesn't kick out until about 2000 rpm, so it will not show true compression when cranking the engine. May only show between 50 and 60 psi.
#13 greencoach47 OFFLINE
greencoach47
  • 8 Thanks
  • 85 posts
Posted May 18, 2011 - 07:58 AM
Wecome Justpics, all good advice and yes take the time to hit everything with your greasegun and fully tune your motor according to th service manual, checking all your gaps.
