Picked this up Yesterday what do yo think
15 replies to this topic
#1 MNGB OFFLINE
MNGB
  • 1,971 Thanks
  • 1,338 posts
Posted July 17, 2016 - 03:59 PM
Hi all, well its never to early to get ready of winter at least here in MN :wave: or now is the time to get the best deal. Anyway my intention is to mount this on the 1614 PK this fall leaving the 10 hp Sno0king engine in place to power it, the seller fabricated this mount to use with his 4 wheeler he said it worked pretty good but then got a very good deal on a nice big Simplicity with 60" deck snowblower and a really nice cab so he listed this on CL for $75.00 I figure the engine is worth that.
  • Gtractor, MH81, grnspot110 and 5 others have said thanks
#2 glgrumpy OFFLINE
  • 8,564 Thanks
  • 7,881 posts
Posted July 17, 2016 - 04:06 PM
Looks good shape for that money. Think might be out there aways hanging off front of tractor?  Without engine would be back more, but probly easier to run it whole, rather than make up a drive lay-out on a PK.  Seems PK ones are kinda complicated and not that good of deal actually. This one will have more blowing power too I'm sure, only single stager's on PK's.
  • boyscout862 and MNGB have said thanks
#3 MNGB OFFLINE
MNGB
  • 1,971 Thanks
  • 1,338 posts
Posted July 17, 2016 - 04:19 PM
Hi Grumpy, yep that's my worry to that it might be a little far out with the engine where it is time will tell, was also thinking it is workable then it should have plenty of power likewis have only seen this type of single stage units on the metal PK's
#4 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted July 17, 2016 - 05:16 PM
  With that much weight hanging that far out, better hang lots of weight on the rear or you won't push it thru 6" of powder.
                                         Mike
#5 MiCarl ONLINE
MiCarl
  • 1,913 Thanks
  • 1,020 posts
Posted July 17, 2016 - 05:24 PM
When it's on the ground the weight will be off the tractor.
Looks like the guy did a decent job with the fabrication.  Hard to go wrong at $75.
  • MNGB said thank you
#6 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted July 17, 2016 - 05:56 PM
Motor is worth more than what u paid!
Good score!
#7 propane1 ONLINE
propane1
  • 8,480 Thanks
  • 4,040 posts
Posted July 17, 2016 - 06:01 PM
I would say that will work good. I have the same thrower on the rear of my MF 12. I have an 8 hp motor on mine, but would like to find a 10 hp for it.
Noel
  • MNGB and jimmy G have said thanks
#8 classic ONLINE
classic
  • 5,177 Thanks
  • 2,234 posts
Posted July 17, 2016 - 06:18 PM
At that price you can't go wrong. It will be interesting to see how it works out.
#9 icpik OFFLINE
icpik
  • 22 Thanks
  • 40 posts
Posted July 17, 2016 - 06:39 PM
Don't know if you are plowing over asphalt or gravel and I have never used this type blower.  But I was wondering if the equipment is too heavy to lift or push, would mounting it on wheels help?  Guess the wheels would be set so the face was 1/2 to 1 inch off the ground. A mid or rear blade would remove the rest of the snow.  Then again in Minnesota, unlike here, you might leave several inches of packed snow.
Don Hayes
Central Virginia, where we don't drive well on snow.
#10 MNGB OFFLINE
MNGB
  • 1,971 Thanks
  • 1,338 posts
Posted July 17, 2016 - 07:35 PM
Hi all thanks for the replies, as to what type of surface I have all of the above asphalt, concrete, mowed grass, pushing the blower I don't think would be a problem but lifting it may, and it may mount to far forward to work, since I have at least 4 other tractors with blowers this will be a project to see if it can be done and work if it can't be mount no loss if it can it will be fun to give it a go.
I've been thinking over a couple of lift ideas, 1 fabricating a mt like the dozer blade system (will it be able to lift it?) 2 extend the frame all the way under the tractor and use the 3 pt hitch  having a pivot point near the middle of the tractor, as is used on the BobCat blowers they look very heavy also, but that system works for them. The tractor has ballasted tires wheel wts and I have a wt bucket that mts on the 3 pt arms.  The idea of wheels to support it is a thought but makes for very hard to turn unless they are castering types.
#11 a.graham52 OFFLINE
a.graham52
  • 115 Thanks
  • 126 posts
Posted July 17, 2016 - 07:44 PM
Weight wise it looks lighter then my Bob cat. My 2414 moved the bobcat around well however steering was a bit hard with it in the air.
Ask yourself this, where is the blower going to be 99% of the time?... dragging on the ground where only pushing forces are being used from the tractor. Every thing else is just give-n-take
#12 MH81 OFFLINE
Posted July 17, 2016 - 09:36 PM
You got a good deal.
Hope it'll work well for you.
A spring assist might help, or is there any way to mid mount and hang a counter balance further back?
#13 MNGB OFFLINE
MNGB
  • 1,971 Thanks
  • 1,338 posts
Posted August 31, 2016 - 08:41 PM
Hi all, well there's no snow forecast but I got the Haban SB into the shop this afternoon to give it a look over and clean the carb to get the Tecumseh running as it should, also run the 1618 up to it to see how it looks. I think its going to work out and its not as heavy as it looks, I'll post some pictures as can be seen the engine is close to the bumper but I intend to try this on the 1976 1614 and the bumper on it is 4" shorter (closer to the grill) and that means the blower will be a bit closer to the tractor shortening the wt arm.
#14 jimmy G OFFLINE
jimmy G
  • 1,178 Thanks
  • 762 posts
Posted September 01, 2016 - 01:25 AM
If you can get down pressure on the blower the weight of the tractor is transferred to the rear and works good on flat driveway's, propane 1s back blower is the most efficient way just hard on the neck
#15 MNGB OFFLINE
MNGB
  • 1,971 Thanks
  • 1,338 posts
Posted September 01, 2016 - 07:16 AM
Hi jimmy G, thanks or the reply but I have to ask why do do you think down pressure is needed? I have 5 other snow blowers on that many other GT's and none have down pressure, and my areas to remove snow from are not flat with virtually none of it hard surface, as for traction wheel wts and other wts are used & needed the PK has ballasted rear tires plus the wheel wts..
