High octane gas in small engines
16 replies to this topic
#1 jggardner83 OFFLINE
jggardner83
  • 3 posts
Posted May 17, 2011 - 12:27 PM
Are there any limitations or guidlines for using 93 octane gas in tractors?
#2 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted May 17, 2011 - 12:49 PM
It won't hurt but it isn't really needed. You are better off running ethanol free gas. With that being said we have been getting 93 octane ethanol free for a while but with the way gas prices are going we are just going to start running 87 octane with 10% ethanol and just be more maintenance oriented and make sure we drain the tanks and bowls when we know the stuff will sit for a while.
#3 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted May 17, 2011 - 02:07 PM
DITTO
A friend of mine uses aviation fuel I think 108 and never has a carb problem. Of coarse no alcohol or water is in that stuff.
#4 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 17, 2011 - 03:04 PM
The high octane gas does not burn properly in a small engine because of the lower compression ratio. Runing 93 octane will cause the fuel to not burn all the way and will cause the motor to loose power,
#5 Billygoat OFFLINE
Billygoat
  • 76 Thanks
  • 206 posts
Posted May 17, 2011 - 06:15 PM
Higher octane gas just burns slower than the lower octane stuff. If you are not having any spark knock with 87, there's no advantage to running higher octane. As1978murray said it can lead to less power, and probably higher fuel consumption.
#6 RustyTub OFFLINE
RustyTub
  • 26 Thanks
  • 137 posts
Posted May 17, 2011 - 07:11 PM
I just run Ethenol Free 91 octane we get around here. The ethenol has been nothing but issue to all of my small engines. I even drain the tanks and run the carbs dry and still have issues.
#7 WQDL753 OFFLINE
WQDL753
    Bolensholic
  • 59 Thanks
  • 301 posts
Posted May 21, 2011 - 09:33 PM
All I know, is my Huskivarna manuals say high octane or they will overheat, and I've always tried to run at least mid grade in an air cooled engine.
They seem yo be happier and give fewer problems when I do.
#8 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted May 21, 2011 - 09:48 PM
I think what we are trying to say here is that we need to avoid the alcohol to prevent this corrosion issues we see with the blended fuels of today. I do not even think the new "box store" tractors will do well on the blended fuel. Think about it. How much maintenance do guys do that buy" box store" tractors do? Lucky if they can change their own oil.
#9 Billygoat OFFLINE
Billygoat
  • 76 Thanks
  • 206 posts
Posted May 22, 2011 - 05:20 AM
I really haven't seen any more problems with blended fuel than I did with unblended. The guidelines I see people post for "extra" attention needed when running E-10 is pretty much the same as manufacturer's instructions back when running unblended. I do get worse gas mileage with my Dodge Ram with a 5.9 though. Keep fresh fuel in your equipment and it should be fine. If you are storing for a while, drain the fuel and put it in your car/truck. No, it doesn't hurt anything to put the mixed up 2-stroke fuel in your vehicle. By the time it's mixed with 1/2 to full tank in vehicles, it's diluted plenty.
#10 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted May 22, 2011 - 05:32 PM
Hey Guys I have used racing gas mixed with regular gas. The racing fuel with lead in it keeps the gas stable longer. Do not run a full tank of racing fuel it could cause engine issue.I also found a new fuel addtive called Ethanol Shield it is good up e15 gas.I am working on article for lagc on this product. stay tuned for that. If you want more info go
www.ethanolshield.com
#11 Texas Deere and Horse OFFLINE
  • 14,886 Thanks
  • 15,514 posts
Posted May 22, 2011 - 05:49 PM
Josh, Thats a good idea. I have a neighbor that races,I will check with him on where he gets his racing gas at.
#12 wilberj ONLINE
wilberj
  • 5,095 Thanks
  • 5,625 posts
Posted May 22, 2011 - 07:59 PM
Most Gas places within a area were a race track is will have Raceing gas.
What do you need to run high octane any ways? Reg is just fine
#13 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted May 22, 2011 - 08:22 PM
It is not about the octane it is the lead in the fuel.
#14 wilberj ONLINE
wilberj
  • 5,095 Thanks
  • 5,625 posts
Posted May 22, 2011 - 08:40 PM
Last time I know there is no lead in fuel any more.
#15 Bolens 1000 OFFLINE
  • 15,406 Thanks
  • 18,277 posts
Posted May 22, 2011 - 08:45 PM
:ditto:
I do mix lead additive in all my equipment though
