Found a MTD 990 today on Craigslist. Went out and looked at it. Offered the guy 350 and he excepted. It came with a snow plow. It runs but the starter needs some work and a new ignition switch as well. I only know a little bit about these tractors. If you can tell me anything about this tractor please let me know I would love to hear about it.
Nice find. It's a later model given it has a starter and no generator. Also, no 3 bolt front wheels. I see you have the rear lift links for the 3 point arms but no lift arms. They're not that complicated if you want to make a set. Looks in good shape. Check the frame on the left side behind the rear wheel for cracks. There's a hole there and the frame likes to crack on a thin spot.
That's a great score!
Looks to be in really good shape!
The first 990's had a low bump out for the starter generator.
The next production run had a high bump out.
The last run had no bump out.
I think that makes yours a late seventies -early eighties model.
I never thought I would be lucky to buy one either because they are rare in this area as well. I spend several times throughout the day looking on Craigslist hoping to find something. I just lucked out this time.
I will have to see if I can track down the mower lift carriage along with the draw arms for the 3 point because I would like to use the plow. I've looked on ebay for hitch parts but found nothing. Any suggestions on where I might find them other than finding a parts tractor?
Here are some more pictures of the tractor. I was finally able to get it home today. The owner also had a pair of tire chains that he threw in. I've included pictures of the engine ID number.
The White Yard boss stopped using the 990 style in 78' , the long frame or what MTD called the 995 was used from 79 on. There were no true White yard boss after 82 or so, Allied sold the name to MTD and the disposable tractor was born
What are the major difference between the 990 and 995?
I also know of a 50" mower deck that has all new spindles installed for $200. It looks like the quick attachment style because it has 2 hooks in the front and 2 in the rear. I've heard that these deck don't cut very good. Is this true?
I use the 50" deck to cut my back field. I would say it is not the best cutting deck I have used. The tractor's large turning radius does not help either. These days if you can get a good rebuilt deck for $200, that would be a good find. Most are nearly destroyed.
The roller shaft on the rear bends easily. I replaced it with two adjustable 5" caster wheels using the adjustable brackets from the roller. The side skid bars tend to dig in too.
The 995 tractor has a twin cylinder engine, the under and front spline shaft PTO are one shaft. Motion control is on the left side. Dash tower is different. Lift carriage and height adjustment is different. Really, the only thing similar are the transaxle, hydraulic system and wheels and tires.
You can download the 995 manual in the manuals section at the top of the forum to compare it.
Get little tractor. Been keeping an eye out for one myself.
Related Threads
Garden Tractor Forums
951.2K posts
49.2K members
Since 2010
