Axle setup on 314
No replies to this topic
#1 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 17, 2011 - 11:27 AM
I've replaced the axle bushings and pivot bolt on the 314. The front of the bolt goes through a bracket that bolts to the front crossmember. Does anyone know if the clearance for the axle to the bracket can be adjusted by moving the bracket? I don't want the new bushings to wear out prematurely because the bracket is out of adjustment. Has anyone ever added a grease fitting to the front pivot bolt or axle?
