Bolens 650 Regulator Wiring?
bolens 650/850 wiring charging circuit electrical
9 replies to this topic
#1 flyboy OFFLINE
flyboy
  • 59 Thanks
  • 50 posts
Posted July 14, 2016 - 07:45 PM
I DON'T GET IT!  I've found a number of schematics online and they all show the same thing at the regulator. Look at the attached jpg and note the red circle.
On my Delco Remy regulator there are 3 terminals: F, BAT & GEN. I assume the L is the Gen terminal on this schematic.  Is the red circled area showing me a 4th terminal somewhere OR does that mean that the wire (#3) coming from the solenoid (solinoid?) connects to the BAT terminal?  Currently I have that wire (#3) connected to the GEN terminal and have 12.6 volts, but I think I should have 13 to 14 volts.  Essentially I don't have enough voltage to charge the battery and hope I haven't destroyed anything.
#2 Mtypython OFFLINE
Mtypython
  • 415 Thanks
  • 378 posts
Posted July 14, 2016 - 08:14 PM
Should be a wire coming from the bottom of the regulator that goes to the solenoid thats how it is on my 1053 and what i can tell from your diagram
  • flyboy said thank you
#3 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 14, 2016 - 08:22 PM
Thats the wrong diagram for your machine, take a look at page 17 of this service manual
http://gardentractor...35-bolens-1220/
http://gardentractor...anual-552875-1/
You should be getting a reading of around 13-14.5 volts if the starter and regulator are functioning properly.
Edited by Bolens 1000, July 15, 2016 - 09:27 AM.
Added the correct link!
  • boyscout862 and flyboy have said thanks
#4 flyboy OFFLINE
flyboy
  • 59 Thanks
  • 50 posts
Posted July 14, 2016 - 09:04 PM
OK!  - It looks like another terminal to me also. I'll unbolt the reg and look for it.
P.S. - I really like your Red Green quote!  - I agree with that!
#5 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5127 Thanks
  • 2912 posts
Posted July 15, 2016 - 09:16 AM
That's the wrong diagram for a 650.  ...The 650 used a D/R regulator, while the Tecumseh on a 1220 used a solid-state regulator/rectifier.
  • Bolens 1000 and 29 Chev have said thanks
#6 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 15, 2016 - 09:26 AM
Oops I put the wrong link in that post, should have been for the service manual, I must have put the other link in the Bolens 1220 thread :wallbanging:
  • 29 Chev and flyboy have said thanks
#7 flyboy OFFLINE
flyboy
  • 59 Thanks
  • 50 posts
Posted July 19, 2016 - 07:02 AM
Thanks for your efforts!   I did not find any 4th terminal on the bottom of my regulator, just 2 resistors and several crimped connection points, no terminal. This leads be to believe that I may have the wrong regulator. But that isn't exactly true. I had the regulator and generator combo tested at a automotive motor shop and both were providing the proper charge output. The generator alone does output 13.5 to 14V So, the only thing left is improper wiring. Thanks to Dr. Bolens for the manual link - I'll look there.
  • Bolens 1000 said thank you
#8 Bruce Dorsi ONLINE
Bruce Dorsi
  • 5127 Thanks
  • 2912 posts
Posted July 19, 2016 - 09:43 AM
Can you post the D/R numbers of the starter/generator and regulator you are using?
The start/gen number can be found on a tag fastened to the start/gen.
The regulator number is stamped into the metal mounting bracket.
Are you certain your regulator is grounded properly?  ....If the regulator is not grounded, it can not control the output of the generator.
If the regulator has mounting feet with rubber cushions, there should be a small bare wire connecting the regulator to the mounting bracket.
#9 flyboy OFFLINE
flyboy
  • 59 Thanks
  • 50 posts
Posted July 21, 2016 - 06:58 AM
I double checked the ground at the regulator base and it is good. I also checked foe continuity between the regulator base and generator housing and that is good also. Yes there is a grounding tab over the regulator base mounting screw holes that is spot welded to the regulator base. The number on the regulator are 1115  165E also: 12VN  8F. And the generator/starter: 1101696  also: 9F30.
Thanks for your help!!
#10 flyboy OFFLINE
flyboy
  • 59 Thanks
  • 50 posts
Posted July 22, 2016 - 01:11 PM
I got it working!  Thanks for all your input(s) and replies!  The diagrams and suggestions helped me determine that I had a wiring error, (the ground was intermitting). Having corrected that,  the system outputs 13.5 to 14 volts.   YEAAA! :dancingbanana:     Thanks Again!!
  • Bolens 1000 and Bruce Dorsi have said thanks
Also tagged with one or more of these keywords: bolens 650/850, wiring, charging circuit, electrical
