Can someone post a pic from a 317?
25 replies to this topic
#1 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 14, 2016 - 02:05 PM
Can someone post a picture from where to drain the hydro fluid on a 317??
I have searched and searched and so far no luck.
#2 KennyP OFFLINE
  • 40,023 Thanks
  • 46,722 posts
Posted July 14, 2016 - 02:27 PM
Since I have one of these laying in the shop, it looks to me like you take the big tube loose and drain from there.
#3 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 14, 2016 - 02:54 PM
Kenny, in the first picture is it the threaded NP fitting you are talking about??
#4 Trav1s ONLINE
Trav1s
  • 3,509 Thanks
  • 4,493 posts
Posted July 14, 2016 - 03:27 PM
From either side of the tractor you will see a large hard straight down from the threaded end of the filter.  That is the line you use to drain the system.  IIRC it is something like a 7/8" size or ???
#5 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 14, 2016 - 03:52 PM
Trav1s, if you look that the second picture Kenny posted are you talking about the one tube that is coming off the bottom of the rearend? (way below the filter)
Edited by victor3ranger, July 14, 2016 - 03:53 PM.
  • KennyP and Trav1s have said thanks
#6 KennyP OFFLINE
  • 40,023 Thanks
  • 46,722 posts
Posted July 14, 2016 - 03:58 PM
Take the big tube loose that attaches to that fitting. May have to loosen both ends. The first pic shows the rear end upside down and the hydro is not attached.
You don't have to take the fitting out.
  • Trav1s said thank you
#7 Trav1s ONLINE
Trav1s
  • 3,509 Thanks
  • 4,493 posts
Posted July 14, 2016 - 04:07 PM
Yes I am.  Let me see if I have a pic saved somewhere.
#8 Trav1s ONLINE
Trav1s
  • 3,509 Thanks
  • 4,493 posts
Posted July 14, 2016 - 04:12 PM
The best Pic i have is this one that shows the hard line that goes up the left side of the tractor (on the seat) and down to the front of the pump below the filter.  This pic is looking at the assembly like you were standing at the front of the tractor looking back.
#9 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 15, 2016 - 09:31 AM
Guys, thank you very much.
I was able to get the filter changed, fluid changed and now it moves on its own again, whew!
This 317 is one I got a while back and had no idea if anything was wrong with it. Now to get all new tires and figure out if I happen to have a good 317 deck laying around.
Is there some way of looking at the mower decks to tell if it is the correct one for a 317??
#10 hdg4400 OFFLINE
hdg4400
  • 286 Thanks
  • 351 posts
Posted July 15, 2016 - 09:58 AM
victor3ranger:
Here is a document that shows the attachments (including mower decks) that fit your 317 and other 300 series tractors.
Hope it helps.
Attached File  300seriesold-96200.pdf   43.99KB   85 downloads
Harlan
#11 Trav1s ONLINE
Trav1s
  • 3,509 Thanks
  • 4,493 posts
Posted July 15, 2016 - 10:31 AM
Check out Miller Tire for new shoes
#12 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 15, 2016 - 12:08 PM
I looked out in the shop and forgot that I had a new pair of AG's stored away so I had the mounted up this morning for the rear.
#13 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 15, 2016 - 12:11 PM
victor3ranger:
Hope it helps.
attachicon.gif300seriesold-96200.pdf
Harlan
Harlan, after looking that attachment over it seems like there are several different decks that might have come with it. I also see that maybe the draft arms might be different on the 317 compared to the 318??  If that is the case what is the difference between them??
#14 hdg4400 OFFLINE
hdg4400
  • 286 Thanks
  • 351 posts
Posted July 15, 2016 - 02:06 PM
victor...
"Harlan, after looking that attachment over it seems like there are several different decks that might have come with it. I also see that maybe the draft arms might be different on the 317 compared to the 318??  If that is the case what is the difference between them??"
Not really sure what the dimension differences would be. I would guess that trying to use a deck not recommended for your tractor would not work very well, and might not work at all. Would certainly need those draft arms adjusted, probably a different belt, etc.
But hopefully someone here at GTTalk can speak to your question much better than I can.
Harlan
#15 Trav1s ONLINE
Trav1s
  • 3,509 Thanks
  • 4,493 posts
Posted July 15, 2016 - 02:19 PM
When the 317 was originally sold, there were two decks available at the time:
Model 41 = three blade 38" cut (uses long front arms to attach to mule drive)
Model 48 = three blade 46" cut (uses short front arms to attach to the mule drive)
These decks were also used on the 120/140/300/312/314/316Kohler
Draft arms that attached to the frame on the 318/322/330/332 are different due to the move to the "open frame design"  Swapping arms allows the later decks to be used on the earlier machines.
