SEARS HYDRO TRAK SUPER 12 TRANS AXLE COOLING FAN
15 replies to this topic
#1 Xrperry ONLINE
Xrperry
  • 1,168 Thanks
  • 830 posts
Posted July 14, 2016 - 12:37 PM
hi all, i am looking for the cooling fan for my trans axle. anyone have one? its metal
#2 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted July 14, 2016 - 06:16 PM
Those are hard to find....you may want to size it up and check Granger...I can take a photo of one on mine if you need something to go by.
  • MH81 and Xrperry have said thanks
#3 Xrperry ONLINE
Xrperry
  • 1,168 Thanks
  • 830 posts
Posted July 14, 2016 - 06:20 PM
thanks john, good idea, i have whats left of mine, just missing a few blades
#4 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted July 14, 2016 - 06:48 PM
Just make sure of the rotation ....cw or ccw
  • Sawdust and Xrperry have said thanks
#5 MH81 OFFLINE
  • 29,978 Thanks
Posted July 14, 2016 - 06:56 PM
You might also check with site sponsors
  • Xrperry said thank you
#6 glgrumpy ONLINE
  • 8,803 Thanks
  • 8,014 posts
Posted July 14, 2016 - 10:14 PM
Check Searsparts.com?  They have odd little stuff sometimes for many older tractors. Need to know your model numbers to search.
#7 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted July 15, 2016 - 05:09 AM
29
on diagram
FanPart #: 8093H
We're sorry. This item is no longer available.
#8 Xrperry ONLINE
Xrperry
  • 1,168 Thanks
  • 830 posts
Posted July 15, 2016 - 08:19 AM
thanks john
#9 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted July 15, 2016 - 07:34 PM
thanks john
Thank you for bringing up this topic , I took a look at mine today and I have one blade left. I have another complete rear end out of another hydro to match it up so I do have a blade for now but I am going to be looking for one in the future so keep me updated if you get one before me. I am sure it will help someone else looking for one as well.
#10 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted July 17, 2016 - 07:40 AM
Not sure if you know any of this but figure I would ask you since you have a hydro to
If you look at the photo the parts 75 76 and 77 you will see they are o-rings I think I have a slight leak from that area. I don't think it will be that hard to tackle but as expected the parts are NLA..... I am sure I can match them up though. If you have any info on this I would appreciate it
Next is a filter and a pan gasket...OK the gasket is NLA and the Filter is NLA ....I really want to change this filter I hear they are the same as the MF12 hydros but I am not sure what to get . Have you done this yet? Do you know where to get a filter and possibly a gasket?
Last question is the vent tube....mine seems to be real short, the one if the diagram seems to be long with a loop on top. Looks to me to be standard lines so I am thinking of making a new vent tube...do you have a photo of yours installed? I would like to route this correctly and the diagram just don't help any.
#11 Xrperry ONLINE
Xrperry
  • 1,168 Thanks
  • 830 posts
Posted July 17, 2016 - 10:25 AM
I have not dug into the hydro yet, it's leaking oil out the left axle tube, by the looks of diagram the axle tube pulls off ,o ring and oil seal in tube? Bearing seems fine. Lucky for me the hub seems a little loose, been covered in oil for god knows how long.tomorrow I will post a pic of tube, mine has the long loop in it.filter and gaskets ,I don't know anything about them, my guess is you can make a gasket.i had to make a case gasket for a simplicity 2 wheel tractor, all one piece, now that was fun.lol. Someone didn't want to pull it apart to change a axle seal so they filled it with grease!!. Yea what a mess, took 3 days just to clean grease out of everything.
Edited by Xrperry, July 17, 2016 - 10:28 AM.
  • John Arsenault said thank you
#12 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted July 17, 2016 - 08:20 PM
I will be taking the top linkage apart tomorrow after work if I have time. I think I just need some o-rings and have a viton rubber o-ring kit so hope I got some in there that matched up.  If your doing the axle seals maybe we should start a suburban hydro transmission thread. Mine are not leaking but my guess is they will be one day. I will also go get me a piece of vent tube I got a line bender and a flare tool so that should not be hard to mimic
Here is what is left of mine ...I knew there should be something there not just a stub.
Sorry so dark it got late and my shop lights just don't do it for me as far as pictures are concerned
#13 Xrperry ONLINE
Xrperry
  • 1,168 Thanks
  • 830 posts
Posted July 17, 2016 - 08:28 PM
good idea on thread, i will take a pic of vent tube tomorrow, tractor is stored at work
#14 Xrperry ONLINE
Xrperry
  • 1,168 Thanks
  • 830 posts
Posted July 18, 2016 - 06:08 PM
jIMG_06961.JPG ohn is this what you wanted?
#15 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted July 18, 2016 - 06:38 PM
Perfect thats what I was thinking just along the fender .....mine was filled with silicone so it was just a plug.
