Jake 1450 Super Chief stuck in reverse!
jacobsen 1450
21 replies to this topic
#1 WaltRider OFFLINE
WaltRider
  • 8 Thanks
  • 12 posts
Posted July 14, 2016 - 08:04 AM
Hi everyone!
I've been mowing and pulling with my 1450 for 6 or 7 years now, and except for general maintenance and pully/spindle work it has been working like a champ!
Electric deck lift works great, mows great, lots of power.
But yesterday I lost all forward gears, and can only run the tractor in reverse.
Any suggestions or help will be greatly appreciated!
Thanks!
#2 boyscout862 OFFLINE
  • 13,558 Thanks
  • 9,431 posts
Posted July 14, 2016 - 08:46 AM
Welcome to GTT. I'm not sure what is going on with your trany. You can download the manuals from our Manuals Section and see what they have to say. There is a section for transmission manuals. Someone will be along to help also. Good Luck, Rick
  • WaltRider said thank you
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted July 14, 2016 - 08:49 AM
:welcometogttalk: :camera:
#4 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted July 14, 2016 - 09:40 AM
Hi, and welcome!
Correct me if Im wrong, but isnt a super 1450 a hydro trans, and not a gear?
#5 MM MARK OFFLINE
MM MARK
  • 82 Thanks
  • 38 posts
Posted July 17, 2016 - 05:34 PM
If we are talking about a hydro you need to check the linkage you have a pivot like a tie rod end that wears and bushings and a set screw at the shaft coming out of the transmission that may have come loose, this must seat in a detent on the shaft to center forward and reverse.  Remove fender/seat pan to inspect.   Good Luck
  • Alc and WaltRider have said thanks
#6 WaltRider OFFLINE
WaltRider
  • 8 Thanks
  • 12 posts
Posted July 27, 2016 - 02:31 AM
Yes, Stiemmey, my 1450 has a hydro trans.  I'll download manuals and check the linkage.  Thanks!
#7 FixItCharlie OFFLINE
FixItCharlie
  • 578 Thanks
  • 363 posts
Posted July 27, 2016 - 08:00 PM
I had not lost forward or reverse in my LGT145 but was close. This will show what I did to repair what I found. http://gardentractor...gt-145-repairs/
Charlie
#8 HALFSCALE OFFLINE
HALFSCALE
  • 515 Thanks
  • 537 posts
Posted July 28, 2016 - 02:56 AM
Charlie
Your 145 has an Eaton and the 1450 has a Hydro- gear, completely different.
#9 KennyP ONLINE
  • 40,975 Thanks
  • 47,147 posts
Posted July 28, 2016 - 03:32 AM
Here's the Jake Hydro-Gear.
  • HALFSCALE said thank you
#10 MM MARK OFFLINE
MM MARK
  • 82 Thanks
  • 38 posts
Posted August 13, 2016 - 08:46 PM
Walt did you get to look at your 1450 yet?
#11 WaltRider OFFLINE
WaltRider
  • 8 Thanks
  • 12 posts
Posted August 16, 2016 - 02:18 PM
Hi everyone!  Yes, I finally got to my Jake and after checking transmission oil I looked under the seat as per MM MARK and the linkage was not connected.  First I tried to see if just placing the tie-rod over the gear selector lever on the transmission would hold, but quickly found out it would not.  As a temp fix I've wired them together so I can mow.  Have some pics in my gallery, but not sure how to share them on this thread!  Will try that next.
  • MM MARK said thank you
#12 WaltRider OFFLINE
WaltRider
  • 8 Thanks
  • 12 posts
Posted August 16, 2016 - 02:22 PM
03 JakeTag
#13 WaltRider OFFLINE
WaltRider
  • 8 Thanks
  • 12 posts
01 LinkageFail
#14 WaltRider OFFLINE
WaltRider
  • 8 Thanks
  • 12 posts
02 FailurePoint
#15 KennyP ONLINE
  • 40,975 Thanks
  • 47,147 posts
Posted August 16, 2016 - 06:14 PM
Now we can find a way to fix this issue. Take that ball out of that end. Take the other end off. Measure thread sizes and find new on line! They are out there!
Also tagged with one or more of these keywords: jacobsen 1450
