Which WIX rearend filter for 317?
14 replies to this topic
#1 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 13, 2016 - 08:31 AM
I have a 317 that has a Onan engine.  Trying to figure out which WIX filter to use on it. I went on the WIX site and it show a #51348 if it has a Onan replacement engine and a #51410 if it still has the Kohler. Why would they change the filter for the rear if it had a engine swap??
I would think the engine itself would have no bearing on what filter was used on the Hydrostat.
#2 Alc ONLINE
  • 7,129 Thanks
  • 7,532 posts
Posted July 13, 2016 - 08:35 AM
That 51348 is an engine oil filter, I have the trans filter for the 318 in the garage if you think that's the same
  • DougT said thank you
#3 KennyP ONLINE
  • 40,192 Thanks
  • 46,797 posts
Posted July 13, 2016 - 08:57 AM
I just looked up the 317 at JD and their filter is an AM39653 which crosses to the Wix 51410.
  • ducky, Alc and Trav1s have said thanks
#4 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 9,997 Thanks
  • 3,237 posts
Posted July 13, 2016 - 09:20 AM
Here is the listing from the Wix filter website application guide http://www.wixfilter....aspx?Section=1 in pdf form - it confirms the part number that KennyP posted.  If you go to the Wix website and look it up you can click on the part number to view the specs - fyi
#5 hdg4400 OFFLINE
hdg4400
  • 286 Thanks
  • 351 posts
Posted July 13, 2016 - 09:26 AM
My 318 uses the same JD and Wix filters. Here's the tranny cross reference I have (probably from another GT forum) for other manufacturers:
Hydro Filter:
AM39653 cross to:
Stens 120265 Purolator L14670 Purolator PureONE PL14670 Fram PH2844
Wix 51410 AC Delco PF13 K&N HP-2004
Bosch 3402 Mobil M1-204 STP S16
I recently changed the filter and fluid on my 318, and went with the Wix filter. I also changed the air filter, Wix again, and found it a little pricey, over $20.
Harlan
#6 GWest OFFLINE
GWest
  • 554 Thanks
  • 505 posts
Posted July 13, 2016 - 09:32 AM
Something I discovered with Wix filters.
They  will show a replacement filter for a OEM filter number which is as close to a match as possible.
If you go to the Wix application charts they may recommend a totally different filter.
Years ago I was involved with a couple of field surveys Wix did for two large companies. They always compared the OEM filter to what they thought was a better choice if there was one and that is how the differences were created. They said we should always use the Wix application charts and I think they were correct.
Garry
Edited by GWest, July 13, 2016 - 09:35 AM.
  • Alc, KennyP and hdg4400 have said thanks
#7 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 13, 2016 - 11:31 AM
Ok, now I feel like a boob.
I started thinking if that might be the case.
#8 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 13, 2016 - 11:32 AM
Thank you Sir, now I guess I have to run to town and get the correct filter for this thing.
#9 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Thanks everyone, this helps a lot. :thumbs:
#10 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted July 13, 2016 - 01:26 PM
Same filter as the oil filter on a 4.0 Jeep
#11 Trav1s OFFLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted July 13, 2016 - 01:30 PM
 Really?
#12 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Same part #
  • Trav1s said thank you
#13 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted July 14, 2016 - 09:47 AM
The 51348 is the same one as my PT Cruiser. At least my Onan and PT cruiser will use the same engine oil filter :D
#14 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted July 31, 2016 - 12:20 PM
I think thats the same as my 300 if im not mistaken i work at a napa store so i crossed the jd here last year
#15 Bolens 1000 OFFLINE
  • 15,298 Thanks
  • 18,236 posts
Posted July 31, 2016 - 12:36 PM
JD AM39653  crosses to our USA made filter:
http://bolenspartsan...orse-cub-cadet/
  • backwoods said thank you
