Jacobsen Tiller Mount
jacobsen 1450 tiller 59713 tiller mount
6 replies to this topic
#1 KennyP ONLINE
  • 38,274 Thanks
  • 45,881 posts
Posted July 11, 2016 - 06:32 PM
This is the mount for a model 59713 Tiller attachment for a Jake 1450 (or similar) tractor. I have one tractor and 2 tillers, but only one mount. So I have been planning this build for some time. I have been collecting necessary metals needed and got to a point of starting the build. I had one tiller attached, so I had to dismount it to get the part needed to build from.
This is what I hope to clone:
I took 2 pieces of 3/4" plywood and attempted to layout the mounting pin holes. That didn't work out.
Using the original mount, I was able to mark the pin locations and drill holes. These were used to locate the tubes so I could weld the plates on.DSCN1944.JPG     DSCN1949.JPG
On this assembly are 2 items I can not clone, so will have to seek outside assistance for those (circled in Blue here).
I put the two 3/4" pins in their holes and set the respective tubes to match the originals. Once that plate was welded on, I inserted the 1/2 pin and tube to weld it's plate on.
That all complete, I made the center brace and welded it in. Time to check it out against the original.
The two pins that attach this to the tractor lined right up with the original. The tiller mount tube is a little off, but that is not an issue I can see.
Now to source the above items and the pulleys. The springs will be another set of items to source.
  • Alc, tractorgarden and 29 Chev have said thanks
#2 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 8,595 Thanks
  • 2,831 posts
Posted July 11, 2016 - 07:36 PM
The flat piece with the slotted hole should not be too hard to make.  Drill two holes the correct diameter at the ends of where the slotted hole should be.  Scribe a line along the edge of the holes where the slot should be.   Then drill small holes (3/16")  in a line drawn 3/16" in from the two scribe lines near where each flat edge of the hole should be so that you have a line of holes in between the two large holes - space them 3/16" apart from each other.  Increase the small hole diameters one drill size up and the piece of metal where the slot should be should fall out and then finish off the flat edge with a file.  You can also use a hack saw to get close to the correct size by removing the blade from the saw frame, then place it through the hole and insert it back in the hack saw frame.  The cut little notches spaced about 1/8" apart to the edge of where your scribe line is.  It is a bit of work but you can test out your cooling devise while you sweat to your favorite tunes doing it.
Edited by 29 Chev, July 11, 2016 - 07:36 PM.
#3 KennyP ONLINE
  • 38,274 Thanks
  • 45,881 posts
Posted July 11, 2016 - 08:02 PM
If I'm looking at the slotted hole correctly, the dia. is such the bit would be overlapping the first hole. I'll measure it tomorrow. Don't think my hand would like the hack saw!
#4 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted July 11, 2016 - 08:08 PM
How about something like this for the pulley?
Slotted holes are a pain, but can be formed with a die grinder or dremel type tool.
Edited by Bmerf, July 11, 2016 - 08:10 PM.
  • CanadianHobbyFarmer said thank you
#5 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 8,595 Thanks
  • 2,831 posts
Sorry - I forgot about your hand - hope it keeps getting better.
#6 KennyP ONLINE
  • 38,274 Thanks
  • 45,881 posts
Posted July 12, 2016 - 07:28 AM
I measured the slot this morning. It is 5/8" wide X 1" long. I'll study that and look around at what I may have. It is for the handle to actuate the belt clutch for the tiller, as seen in the first two pics above. I may have something around here that has a slot like that I could make work. The other part is a 3/4" rod with the end turned down to 5/8" for a pulley bearing to mount on. It has a threaded hole in the center of it. That I cannot accomplish.
#7 KennyP ONLINE
  • 38,274 Thanks
  • 45,881 posts
Posted July 12, 2016 - 12:39 PM
Since we had rain showers off & on all morning, I got the pins made up for mounting to the tractor & tiller.
