Duel Wheel Hub Adaptors?
montgomery ward mw loader duel wheels
9 replies to this topic
#1 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted July 10, 2016 - 10:35 PM
Picked up this beauty for $800. has official Montgomery wards loader on it going to put new hoses and hydraulic fluid in it. where can i get Dual Wheel Hub Adaptors for it?
  • Mark 149 J. said thank you
#2 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted July 10, 2016 - 11:51 PM
I made mine with an old set of rims the same diameter, cut them off to fit inside then used long bolts, it sounds simple but I will have to post you pictures, I will try to do it in the morning, I will start a new topic to share this with others
  • Alc, Montgomeryluv15 and grattone have said thanks
#3 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted July 11, 2016 - 09:28 AM
Very cool!  Only a couple months back I sold OEM Gilson dual adapters   :(
  • Montgomeryluv15 said thank you
#4 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted July 11, 2016 - 09:40 AM
I highly recommend you find dual adapters that bolt onto the axle with the first wheel and then the outer wheel bolts to the adapter, the setup where the outer wheel is bolted to the inner wheel is weak and it puts all the stress on the inner wheel. I once saw a cub that just had the two wheels bolted together with spacers and it bent the inner wheel so bad that the outer wheel ran about 2" out of round.
  • Montgomeryluv15 and John Arsenault have said thanks
#5 OldBuzzard ONLINE
OldBuzzard
  • 7,027 Thanks
  • 4,792 posts
Posted July 11, 2016 - 03:10 PM
:ditto:
You want ones like this.
http://www.xtrememot...s/CC-01-001.htm
#6 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted July 12, 2016 - 06:51 AM
Awesome would you know how rare they are? i have a buddy in Florida that has a Very Rare Montgomery wards 3pt hitch. i want to buy it but he says no.. :)
#7 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted July 12, 2016 - 06:52 AM
Oh damn. i will definitely check into that thank you.
#8 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted July 12, 2016 - 06:53 AM
:ditto:
This product is awesome i love the fact that their taking the Spaced Farm tractor duel wheel look to small garden tractors Thank you for sharing.. :thumbs:
#9 OldBuzzard ONLINE
OldBuzzard
  • 7,027 Thanks
  • 4,792 posts
Posted July 12, 2016 - 11:19 AM
There was another dual wheel option, but as far as I know Bolens was the only one that used it and only on their large frame tractors.
#10 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted July 12, 2016 - 03:57 PM
Gilson/Montgomery wards did Large Frame as well from 65 - 77 i think.
Also tagged with one or more of these keywords: montgomery ward, mw loader, duel wheels
