Poor Man's AC
35 replies to this topic
#1 KennyP ONLINE
  • 37,543 Thanks
  • 45,533 posts
Posted July 09, 2016 - 03:40 PM
Got the idea from a friend. So i started making up my own. Take a box(whatever), put a fan at one end, some ice (what have you) and blow air across it.
Here's my rendition.
  • olcowhand, grnspot110, gopher and 9 others have said thanks
#2 boyscout862 ONLINE
  • 12,567 Thanks
  • 9,048 posts
Posted July 09, 2016 - 04:08 PM
Before the Civil War there was a big business cutting ice in the northern states and bringing it to the southern states for cooling rooms. They used saw dust to insulate the ice.
I remember my grandfather had one of those evaporative coolers that mounted on the car window. Supposedly the air going by evaporated water in the gadget and then cooled air was blown into the car. Didn't seem to do much good but, I was only ten then. Good Luck, Rick
I failed to get that pic so far but, will try again later.
Edited by boyscout862, July 09, 2016 - 04:09 PM.
  • KennyP, Rock farmer, Doxey and 1 other said thanks
#3 KennyP ONLINE
  • 37,543 Thanks
  • 45,533 posts
Posted July 09, 2016 - 04:16 PM
I'll be loading this with 3 2.5 liter frozen jugs and a couple half gallon milk jugs! Should cool me down some!
  • Texas Deere and Horse, boyscout862, Doxey and 1 other said thanks
#4 DougT ONLINE
DougT
    Dog Approved
  • 6,856 Thanks
  • 4,955 posts
Posted July 09, 2016 - 04:30 PM
I knew a local guy that had one of those evaporative window coolers he displayed with his car. claimed he bought it California when he lived there and they used to load it with dry ice. Said it worked fairly well when you were moving and not at all sitting still.
  • KennyP, Doxey and holdenboy1960 have said thanks
#5 Doxey ONLINE
Doxey
  • 196 Thanks
  • 146 posts
Posted July 09, 2016 - 04:31 PM
I agree with the frozen jugs.  I first thought that just ice in a humid area like mine would just make my shop more humid.  Great idea.
#6 toppop52 ONLINE
toppop52
  • 5,038 Thanks
  • 4,644 posts
Posted July 09, 2016 - 04:32 PM
Evaporative coolers work very well when dew points are low, in high humidity they are basically just a fan.
  • MH81, KennyP, boyscout862 and 1 other said thanks
#7 boyscout862 ONLINE
  • 12,567 Thanks
  • 9,048 posts
Posted July 09, 2016 - 04:48 PM
When I was in boot camp I made friends with the supply sargeant(Yancy). I got put on water detail with him the first week. I did what he said and got everything squared away quickly. He liked that I didn't require supervision so from then on I was detailed to him when ever we went to the field. Because we used to take a duece and a half out to the training sites, way ahead of the company, we had lots of time to kill. As soon as we got out there, I would set up the lister bags in a shady area and fill them. we then wet down the outside of them so that evaporation would cool then. He also showed me to wet my canteen cover so that it would cool my canteen. It works. No one else told me about that. I passed it on to the others in my platoon. There are alot of simple but effective techniques out there. Good Luck, Rick
  • KennyP and holdenboy1960 have said thanks
#8 KennyP ONLINE
  • 37,543 Thanks
  • 45,533 posts
Posted July 09, 2016 - 04:59 PM
I ain't worried about humidity as we already have that. If it blows cooler air, then I'm happy!
  • jimbobbillyray and boyscout862 have said thanks
#9 KC9KAS ONLINE
KC9KAS
  • 5,329 Thanks
  • 4,672 posts
Posted July 09, 2016 - 06:17 PM
Hope you didn't work up a sweat building your AC unit! :bigrofl:
  • KennyP, jimbobbillyray, holdenboy1960 and 1 other said thanks
#10 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,857 Thanks
  • 4,350 posts
Posted July 09, 2016 - 06:28 PM
Any little bit helps.... I'm jumping into the pool now. :wave:
#11 Sawdust OFFLINE
Sawdust
  • 5,563 Thanks
  • 3,335 posts
Posted July 09, 2016 - 07:46 PM
I've seen these made out of 5 gallon buckets using dry ice & also coolers with hair dryers rigged for the fans.
#12 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted July 09, 2016 - 07:50 PM
I have an idea I'm going to try out, I would like to solar power a shallow water pump. Well water in my area is around 50 degrees I want to set up a recirculating system using well water thru a coil enclosed in a insulated sheet metal duct with a solar powered fan inside. The spent water will be sent back to the ground via a vertical French drain next to the well point pipe and cool my insulated garage the plans are in the works.
  • TheFarm2004, KennyP, jimbobbillyray and 3 others have said thanks
#13 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted July 09, 2016 - 08:40 PM
Another idea, where a solar powered recirculating pump can be incorporated in the system, cool well water, a automotive, truck, whatever, radiator in the system and solar powered fan blowing air through it.
  • KennyP, HDWildBill, HANKG and 2 others have said thanks
#14 JBRamsey ONLINE
JBRamsey
  • 1,412 Thanks
  • 813 posts
Posted July 09, 2016 - 08:44 PM
A 5000 btu window unit is less than $ 85 and dehumidifies the air at the same time. I picked one up in a Boy Scout yard sale for $ 20.
  • KennyP, jimbobbillyray, HANKG and 3 others have said thanks
#15 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted July 09, 2016 - 10:17 PM
I believe they were called swamp coolers, I have one for my 72 VW bus that I brought back with me from Hawaii when I retired from the Navy.
  • Sawdust said thank you
