old craftsman
12 replies to this topic
#1 Xrperry ONLINE
Xrperry
  • 1,022 Thanks
  • 762 posts
Posted July 09, 2016 - 09:28 AM
hi all, i have an old craftsman rider with a 10 hp vertical tecumseh. i have to full choke it for a few seconds, then put throttle to idle to get it to start. i have to do this 3-4 times before i can get it to run.if you try to give it throttle it will die, it will take throttle after a few tries. i have had the carb apart a few times and found nothing wrong.am i missing somthing?
  • CharlesDes said thank you
#2 boyscout862 ONLINE
  • 12,818 Thanks
  • 9,153 posts
Posted July 09, 2016 - 09:36 AM
Yes. Those carbs have several tiny passages that were plugged at one end, at the factory, with small steel balls. Those passages are nearly impossible to clean. I've had to soak the carbs in carb cleaner for days and hen use compressed air. Down load the manual on the Tecumseh Carbs. Good Luck, Rick
  • Xrperry said thank you
#3 chieffan OFFLINE
  • 10,089 Thanks
  • 6,612 posts
Posted July 09, 2016 - 09:40 AM
Why do they have to make things difficult.  What happened to KISMIF ?
#4 boyscout862 ONLINE
  • 12,818 Thanks
  • 9,153 posts
Posted July 09, 2016 - 10:08 AM
They are out of business aren't they?
#5 dodge trucker ONLINE
dodge trucker
  • 2,413 Thanks
  • 3,110 posts
Posted July 09, 2016 - 10:25 AM
Is this an old enough machine to have had adjustable main and idle mixture screws? Not taking gas from an idle sounds like the mixture needs to be adjusted a little bit richer. Turn the idle mixture screw out 1/8 turn at a time and try it to see if it helps.
#6 Xrperry ONLINE
Xrperry
  • 1,022 Thanks
  • 762 posts
Posted July 09, 2016 - 11:06 AM
i tried that to dodge. thing is after i get it started and warmed up it idles and i have good throttle.the engine is in good shape, i wouldnt even mess with it but the tractor is an old amf built, ugly as sin but i use it at work to pull a little lawn trailer. it grew on me so i think its worth making it right.
Edited by Xrperry, July 09, 2016 - 11:13 AM.
  • rustyoldjunk said thank you
#7 UncleWillie ONLINE
  • 15,657 Thanks
  • 8,756 posts
Posted July 09, 2016 - 11:31 AM
I have had good success with filling the carb up with Seafoam and letting it sit for a day. Make sure the piston is at TDC then (with the spark plug in) fill the carb till it won't take any more. The next day take the plug out and turn it over a few times to clear the cyl and carb out. Then try starting it with just seafoam poured in the feed line.
  • rustyoldjunk and Xrperry have said thanks
#8 EricFromPa OFFLINE
EricFromPa
  • 3,648 Thanks
  • 3,108 posts
Posted July 09, 2016 - 01:45 PM
Does that have the Plastic Emulsion tube in the carb with the 2 goofy rubber seals?
If it does have the plastic emulsion tube then see if you can find and replace the 2 small O rings.If they are cracked or leaking you will never get it running correctly.
Here $4.74 for 2 shipped lol.
http://www.ebay.com/...vIAAOSwKtlWnGe7
This is what they look like installed on the emulsion tube.
#9 Xrperry ONLINE
Xrperry
  • 1,022 Thanks
  • 762 posts
Posted July 09, 2016 - 06:01 PM
it dont have a plastic tube,its an older carb. i will have to take it apart and check it all out
#10 Tecumseh power OFFLINE
Tecumseh power
  • 1,477 Thanks
  • 1,112 posts
Posted July 09, 2016 - 06:22 PM
If has an lme carb, which it probably does it has a brass emulsion tube. Once you unscrew it you need a service replacement. Or you need to take yours and cut a Grove around the holes that are in the threads. When you put it back in. Or it won't run
#11 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted July 11, 2016 - 01:10 AM
That is a fact for sure, found that out first hand. However you can get to the ports and all clean after it is out, and when I put the service nozzle in, mine now runs so smooth and nice it's like a new motor.
  • Xrperry, John Arsenault and Tecumseh power have said thanks
#12 John Arsenault OFFLINE
John Arsenault
  • 2,524 Thanks
  • 1,197 posts
Posted July 11, 2016 - 07:25 AM
I have had a few times in the past rev up the engine with the breather off and at a high mid to high rpm choke out the carb with my hand. By doing that you cause all the suction to pull through the jets, sometimes pulling the debris through and fixing your problem. That only works if you have a piece f dirt , if its clogged up with that white hazy crap it needs to be cleaned out.
#13 Xrperry ONLINE
Xrperry
  • 1,022 Thanks
  • 762 posts
Posted July 17, 2016 - 03:40 PM
Thanks everybody, appreciate info
