Checking for spark on Tecumseh hh120
24 replies to this topic
#16 MH81 OFFLINE
Posted July 12, 2016 - 09:40 AM
Ok. I can do that.
Thanks everyone!!!
Is it ok to ground it out on the engine block?
Best place to do it, just make sure you have a good ground
  • Greasy6020 said thank you
#17 Greasy6020 OFFLINE
Greasy6020
  • 1,477 Thanks
  • 1,399 posts
Posted July 12, 2016 - 12:01 PM
Awesome, thanks!!
#18 Greasy6020 OFFLINE
Greasy6020
  • 1,477 Thanks
  • 1,399 posts
Posted July 12, 2016 - 05:32 PM
So, the motor has very good spark. I just needed to stick a self tapping screw in the ignition to get it to the "run" position.
#19 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,625 Thanks
  • 1,311 posts
Posted July 13, 2016 - 03:56 PM
There are two different companies that now sell aftermarket replacements for the SSI ignition system on the Tecky HH engines. I can't find my link to one of them that I had saved but here is  the link to the other one. http://overnight-sol...s.com/index.htm
Edited by rustyoldjunk, July 13, 2016 - 03:57 PM.
  • ducky and Greasy6020 have said thanks
#20 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,625 Thanks
  • 1,311 posts
Posted July 13, 2016 - 03:57 PM
On another note the last time I checked the new replacements were less than what people want out of 40-50 year old used units.
  • Alc and Greasy6020 have said thanks
#21 MH81 OFFLINE
Posted July 13, 2016 - 08:26 PM
If it has spark, it should run... Assuming no block, valve or compression issues
#22 Greasy6020 OFFLINE
Greasy6020
  • 1,477 Thanks
  • 1,399 posts
Posted July 13, 2016 - 09:17 PM
It felt like it had good compression... My face was a good 18" away and gave my hair a good blow.
Screw it, I think I may as well keep the motor... Just need to get the right hand running board and new tires/rims.
#23 MH81 OFFLINE
Posted July 14, 2016 - 06:30 AM
Any idea why they parked it?
If it developed issues, you can always do a repower then.
#24 TAHOE OFFLINE
TAHOE
  • 7,978 Thanks
  • 5,676 posts
Posted July 14, 2016 - 07:30 AM
There is actually more than that.
*Dale at Overnight Solutions sell a "direct swap" system which somewhat maintains current setup.
*Ed Stoller is considered the pioneer of developing a system which converts it to a battery -coil setup. He doesn't sell a complete kit, but has a friend who sells them. He as also recently worked on a kit using a GM 4 prong HEI module, ABS brake sensor, and a coil.
http://enginesandmagnets.com/
*Brain miller also has various solutions on his website using the Chrysler control box, Ford box ,and also the GM module.
http://gardentractor...om/ignition.htm
* You can also click in my sig and see my write up on the custom ignition on my Tecumseh.
  • rustyoldjunk, ducky, MH81 and 1 other said thanks
#25 Greasy6020 OFFLINE
Greasy6020
  • 1,477 Thanks
  • 1,399 posts
Posted July 14, 2016 - 12:25 PM
I was told they just stopped using it... Parked and forgot was the story.
I asked the po, waiting for a reply now... Will pay further results
Edited by Greasy6020, July 14, 2016 - 12:27 PM.
