Tire loadin update
10 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,147 Thanks
  • 4,282 posts
Posted July 08, 2016 - 11:02 AM
Amazing, never spun a tire. Loaded yesterday with water. 6 US gallons in the right rear and 7 in the left rear, which is the one that spun the most, because of turning left to do the trimming around trees and bushes. And can back up hills I couldn't before. Plus can get in closer to stuff and be able to back out. I filled the jugs to the top and weighed a few. Most were 9 lb.
Noel
  • Sawdust and CanadianHobbyFarmer have said thanks
#2 secondtry OFFLINE
secondtry
  • 2,109 Thanks
  • 1,508 posts
Posted July 08, 2016 - 11:18 AM
Noel
      I have heard good things about tire filling with beet juice, glad the water is working for you. Can any one comment on beet juice experience?     Don
  • propane1 said thank you
#3 MH81 OFFLINE
Posted July 08, 2016 - 11:41 AM
Search the word Rimgaurd or Rim Gaurd here on the site.
Lots of hits.
People love it until they have to change a tire. The juice goes "sour" after a time.
  • boyscout862 and Sawdust have said thanks
#4 olds45512 ONLINE
olds45512
  • 1,344 Thanks
  • 678 posts
Posted July 08, 2016 - 12:16 PM
Just keep I mind that the water will freeze and rip the tire open.
  • boyscout862, Sawdust, propane1 and 1 other said thanks
#5 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,707 Thanks
  • 1,520 posts
Posted July 08, 2016 - 12:36 PM
I know a lot of people like the windshield cleaning solution but that is actually very flammable because of the alcohol in it (I got severally burnt by this when I was a mechanic).  I thought about using RV winterizing solution.  There is no alcohol, -50 F protection, and most have anti-corrosion protection.  I know that is costs more but I think it's a better fluid to use.  I will be putting some in my tractor tires next week.
  • Sawdust and propane1 have said thanks
#6 chieffan ONLINE
  • 10,927 Thanks
  • 6,935 posts
Posted July 08, 2016 - 01:01 PM
I use the RV antifreeze and buy it when it is on sale in early spring.  Cheaper than the windshield washer fluid then - sometimes.  Problem is I keep getting more tires to fill and keep running out of the filler.
  • propane1 and Mark 149 J. have said thanks
#7 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted July 08, 2016 - 02:04 PM
I'm not sure which brand of RV anti-freeze you are using, maybe some are alcohol based and others are not?.I loaded a set of tires with it last year and the jugs were marked as extremely flammable. It is working great for me though, I got about 5-1/2 gallons in per tire, which gave me an additional 40lbs per side.
Jim
#8 Natureboy OFFLINE
Natureboy
  • 83 Thanks
  • 98 posts
Posted July 08, 2016 - 03:14 PM
I loaded mine with RV fluid. Tractor Supply usually puts in on sale in the fall when people are closing up their RV's.
#9 KC9KAS ONLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted July 08, 2016 - 04:56 PM
Noel
FYI....1 gallon of water weighs 8.34 pounds!
#10 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,707 Thanks
  • 1,520 posts
Posted July 08, 2016 - 05:19 PM
Jim
I was looking at Camco rv anti-freeze.  It doesn't us alcohol and it says it will prevent corrosion of most metals.  I don't want my steel rims to rust through over time.
#11 propane1 ONLINE
propane1
  • 9,147 Thanks
  • 4,282 posts
Posted July 08, 2016 - 08:10 PM
When you fill them to where the cap screws on, they are 9 lb. Get a scale and try it, let me know what you get.
Noel
Edited by propane1, July 08, 2016 - 08:12 PM.
  • Sawdust and Mark 149 J. have said thanks
