painting oak..
9 replies to this topic
#1 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted July 06, 2016 - 10:50 AM
I have a park bench in my yard..   My issue is that every couple of years I need to repaint it. I use a good oil based paint and it seems to peel down to the raw wood.. It's like I don't get good penetration into the wood .
  So,, I'm getting ready to paint it again , but wondering if there is anything I should do to prep it or brush on or in to the grain of the oak before my final coat.???  I'm using Rustolium exterior  paint for wood..
        Thanks          sodi
  • Sawdust said thank you
#2 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted July 06, 2016 - 11:05 AM
You might try mixing some linseed oil into it. Make it thinner to penetrate better. Good for the wood too.
  • Alc, boyscout862, sodisr and 1 other said thanks
#3 propane1 ONLINE
propane1
  • 9,470 Thanks
  • 4,398 posts
Posted July 06, 2016 - 12:24 PM
This what I was told to use on cedar shingles. May or may not work for you.
Noel
  • Gtractor and sodisr have said thanks
#4 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,894 Thanks
  • 6,369 posts
Posted July 06, 2016 - 03:15 PM
Have you tried this?  I have been told this before but I have never tried it.  My front and rear deck is painted and every year I have to repaint it because the paint just peels off.  Doesn't seem to actually adhere to the wood, but just lays on the surface.
#5 Rock farmer ONLINE
Rock farmer
  • 1,299 Thanks
  • 1,274 posts
Posted July 06, 2016 - 04:43 PM
Sounds like red oak.
That wood is porous.
It needs to be sealed to take a coating of any kind.
I'd use a deck coating.
Joe
#6 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted July 06, 2016 - 04:50 PM
I've used it many times with good luck. Even did a concrete floor in a garage this way. Seemed to hold it well!
  • Gtractor and toomanytoys84 have said thanks
#7 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted July 06, 2016 - 06:06 PM
Pressure treated wood wont hold paint long no matter what you paint it with..
#8 chieffan ONLINE
  • 11,374 Thanks
  • 7,118 posts
Posted July 06, 2016 - 06:44 PM
Pressure treated don't need anything on it for many years.  Other raw wood I would use a good water seal and forget the paint.
#9 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted July 06, 2016 - 08:03 PM
I would never paint wood that's exposed to the elements. Use a good quality stain. They have many colors available & also you can go with a solid stain or opague that would allow some grain to peak through if that's what you like. I'm partial to Sherwin Williams.
Edited by Sawdust, July 06, 2016 - 08:03 PM.
  • sodisr said thank you
#10 JBRamsey ONLINE
JBRamsey
  • 1,568 Thanks
  • 878 posts
Posted July 06, 2016 - 08:44 PM
My house was a spec house so the builder cheated out on some things. My porch railing and ballisters rotted out after about five years. I replaced them with pressure treated lumber. I bought my lumber, stickered it in my garage and let it air dry a good six months or more. I cut everything to size, sanded it, primed it(twice) with exterior grade Kilz, filled knot holes with bondo, sanded and primed again before two topcoats of exterior enamel. I paid a lot of attention to the ends to keep water from wicking up the grain. Then I pre drilled and screwed it all together. Then more bondo in the screw holes, primer and another layer of paint.
That was 8 years ago and it has shown no signs of rot or peeling. I suspect it's going to outlast me.
Pressure treated can be painted but must be dry and prepped. I would not paint a deck floor. I use stain on it.
  • sodisr and toomanytoys84 have said thanks
