Old Suburbanite Tractor?
antique old tractor suburbanite
13 replies to this topic
#1 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,846 Thanks
  • 1,587 posts
Posted July 05, 2016 - 06:06 PM
Can anybody tell me anything about this tractor?  I have a chance to buy this if I can still get parts for it.
  • Alc, Bruce Dorsi, Lauber1 and 3 others have said thanks
#2 DougT ONLINE
DougT
    Dog Approved
  • 7,117 Thanks
  • 5,080 posts
Posted July 05, 2016 - 06:45 PM
It looks fairly complete. What kind of parts does it need? I know a common Techumseh coil will fit it. It's not like you are going to go to the store and get internal parts off the shelf. the tractor was the last of the Kinkades by American Farm Mach co. If the price is right, I wouldn't let parts stop me. Not sure if I've got the manual posted here or not but have one that would cover the engine and drive.
#3 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,797 Thanks
  • 5,097 posts
Posted July 05, 2016 - 06:51 PM
Shouldn't the head cooling fins be in line with air flow?
AWESOME MACHINE BTW.      BUY IT!!!!!
  • Lauber1 and Mark 149 J. have said thanks
#4 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,846 Thanks
  • 1,587 posts
Posted July 05, 2016 - 06:52 PM
Thanks for that information!
I don't know if it needs any parts yet I just don't want to get it home and find out that you can't really find anything for it.
#5 DougT ONLINE
DougT
    Dog Approved
  • 7,117 Thanks
  • 5,080 posts
Posted July 05, 2016 - 06:54 PM
Here is a manual for the Standard Edgeton. This was the 2 wheel version of the Suburbanite. The engine and drive are the same.
http://gardentractor...dgeton-tractor/
  • Bruce Dorsi, Lauber1, boyscout862 and 2 others have said thanks
#6 MiCarl ONLINE
MiCarl
  • 2,207 Thanks
  • 1,125 posts
Posted July 05, 2016 - 06:56 PM
How fast do you think it goes?  If a sparrow flies past there will be more air flow side to side.
Edited by MiCarl, July 05, 2016 - 06:56 PM.
  • Gtractor and Mark 149 J. have said thanks
#7 DougT ONLINE
DougT
    Dog Approved
  • 7,117 Thanks
  • 5,080 posts
Posted July 05, 2016 - 07:02 PM
You're looking at a machine that was built early to mid 50s and has been out of production since. Probably the most scary thing would be a bad piston and bore from being run lean on oil. It's 2 stroke. If compression is good and it feels tight I wouldn't be too afraid of it. You're mainly looking more of a show piece than a user.
  • Lauber1, boyscout862, Sawdust and 1 other said thanks
#8 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,846 Thanks
  • 1,587 posts
Posted July 05, 2016 - 07:05 PM
Looked at the manual.  Not much for images!  Should help if I end of getting it.
I didn't realize it was a 2 cycle engine.
#9 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,846 Thanks
  • 1,587 posts
Posted July 06, 2016 - 01:15 PM
I bought the Suburbanite tractor!
The motor has good compression and everything seems to be all there so we negotiated a price of $100.  It will be awhile before I get any time to work on it so it will have to sit for now.
There was one interesting thing that I notice about the motor.  On the top of the engine there is a loop/eyelet(Picture 2) that sticks out of the cooling shroud.  When you pull the loop, the spark plug wire moves in the same direction.  I figure this movement kills the engine because the air gap between the coil and flywheel is to great to generate a spark.
20160706_102051.jpg 20160706_102114.jpg 20160706_102126.jpg 20160706_102236.jpg 20160706_102325.jpg
The third picture shows a small pulley for the starting rope.  It's located at the rear of the engine.
The forth pictures shows a small pulley in the front of the transmission to run a sickle bar attachment.
Does anybody know if the red and yellow are the corrrect colors for this tractor?
Edited by Mark 149 J., July 06, 2016 - 05:56 PM.
  • Gtractor, Alc, KennyP and 3 others have said thanks
#10 Gtractor ONLINE
Gtractor
  • 9,797 Thanks
  • 5,097 posts
Posted July 06, 2016 - 04:55 PM
I was figuring on the flywheel having a fan to blow some air.
It can't go very fast or it'd be a "run behind" instead of a walk behind.   :poke:  :rolling:
#11 MiCarl ONLINE
MiCarl
  • 2,207 Thanks
  • 1,125 posts
Posted July 06, 2016 - 06:50 PM
Oh, That.
  • Mark 149 J. said thank you
#12 DougT ONLINE
DougT
    Dog Approved
  • 7,117 Thanks
  • 5,080 posts
Posted July 06, 2016 - 07:32 PM
The red is right but it's the first time I've seen one with a yellow wheel.
#13 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted July 06, 2016 - 07:55 PM
Glad you got it good looking tractor to show. This is one of those fine line items do you restore or leave original.
#14 shorty ONLINE
shorty
  • 5,838 Thanks
  • 5,418 posts
Posted July 09, 2016 - 09:55 PM
A neat piece of history.
Also tagged with one or more of these keywords: antique, old, tractor, suburbanite
