1254 Gear/PTO oil
7 replies to this topic
#1 Viper409 OFFLINE
Viper409
  • 12 Thanks
  • 13 posts
Posted July 04, 2016 - 09:56 AM
I'm looking at replacing the gear oil in the transmission of my 1254. I've read that I could use a GL-5 spec oil, but I've also read that a GL-5 oil could harm the bronze parts inside and that a GL-1 spec is best. What's the right answer? Does this oil also work in the PTO gearbox of the mower deck that I have?
Also, there is no freewheeling pin on the right axle, as the pictures show. Anyone else come across something like this? There is one picture from the front of the tractor, and one from the rear.
Finally, the left rear wheel is leaking oil, which I'm assuming is just a seal. Does this oil come from the transmission, and is it ok to run it like that for a little while until I can get the parts?
Edited by Viper409, July 04, 2016 - 09:57 AM.
#2 Bolens 1000 ONLINE
  • 17303 Thanks
  • 18797 posts
Posted July 04, 2016 - 11:01 AM
You will need to use a mineral 90 weight gear oil in both trans and Gearboxes
I have never seen those axles on any tube frame before! , Someone must have cobbled something together!
Almost looks like hydro static hubs but I dont know....
#3 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted July 04, 2016 - 11:18 AM
You DEFINATELY want the GL1 spec oil.
#4 Viper409 OFFLINE
Viper409
  • 12 Thanks
  • 13 posts
Posted July 05, 2016 - 05:57 AM
Is there anyone in Ontario that knows where to get GL-1 Mineral Gear Oil?
#5 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted July 05, 2016 - 09:31 AM
I've done some searchin
I did a bit of Googling and the best I can come up with is this:
http://www.comatmoto...m/#!about3/cbfk
They are a distributer and don't appear to sell direct.  You might give them a call and see if they can tell you who a local retailer might be.
I know that NAPA has Gl1 oil and I can find it on the US site, but the Canadian site's search function it so crappy that I can't find it there.
You might call you local NAPA and see if they have it.
#6 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 4973 Thanks
  • 2860 posts
Posted July 06, 2016 - 10:28 AM
A lot of the early Ford & Ferguson farm tractors use 90w GL-1 gear oil.
As Dave said, NAPA has it in the USA, as well as Tractor Supply Co. (TSC).
Did you check with Canadian Tire?
#7 Viper409 OFFLINE
Viper409
  • 12 Thanks
  • 13 posts
Posted July 06, 2016 - 10:44 AM
I have had a look around. I found a company that deals in Chevron lubricants, and they can supply a pail of GL-1 at $95 CDN. I think it's cheaper to just go to the US, and grab a gallon or two from NAPA; as I'm only an hour or so from a border crossing.
Canadian Tire doesn't have anything that has a GL-1 spec. I've emailed a couple of tractor dealers near me, and no success there either.
#8 Bruce Dorsi ONLINE
Bruce Dorsi
  • 4973 Thanks
  • 2860 posts
Posted July 06, 2016 - 12:43 PM
Both of these gear lubes are GL-1:
http://www.tractorsu...ion-fluid-2-gal
https://www.napaonli...J65205/FNJ65205
