Gas can spout cap fix
6 replies to this topic
#1 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1692 Thanks
  • 1148 posts
Posted July 03, 2016 - 03:14 PM
  For those who lose the spout cap(myself included) on your plastic gas cans, Fit a piece of 3/4" PVC pipe in a PVC cap. Then clamp it in the vice and with some careful work with the die grinder ream the pipe out to fit snug over the spout. If you don't have a die grinder use the rat tail file before cutting the pipe to fit in the cap.
                                      Mike
  • MH81, Alc, jms180 and 6 others have said thanks
#2 UncleWillie OFFLINE
  • 16501 Thanks
  • 9061 posts
Posted July 03, 2016 - 06:27 PM
i just put a drink bottle on mine
#3 chieffan OFFLINE
  • 16384 Thanks
  • 9034 posts
Posted July 03, 2016 - 07:59 PM
Hydraulic hose end caps work good also.  Sometimes you can find on that fits snug on the tapered spout.  Use a golf tee to plug the vent hole if that cap gets lost.
  • JBRamsey said thank you
#4 adamjd200 OFFLINE
adamjd200
  • 2130 Thanks
  • 2232 posts
Posted July 06, 2016 - 09:51 PM
I've used a clean(debarked) stick to plug a rubber spout on a gas can before, a bolt threaded into the end does the same.
#5 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted July 07, 2016 - 06:36 AM
I have been slowly replacing the spouts around here with these or the high flow version.
http://www.tractorsu...it?cm_vc=-10005
#6 KennyP ONLINE
  • 52532 Thanks
  • 53102 posts
Posted July 07, 2016 - 06:42 AM
And you notice they call it a 'water can' kit!
#7 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted July 07, 2016 - 06:53 AM
Right, the gas can version isn't legal in all 50
