725 running issues
8 replies to this topic
#1 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted July 02, 2016 - 12:41 PM
http://gardentractor...e-new-toys/#got the 725 running but as soon as you give it a little throttle it goes wide open like the governor is out. Pulled the motor and pulled oil pan off expecting to see the gear gone but it is still there and working properly. I don't see anything wrong, any one have any ideas?
#2 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted July 02, 2016 - 01:32 PM
check to make sure the springs and rods are in the correct holes per the briggs manual.
  • rustyoldjunk and powerstroker00 have said thanks
#3 jms180 ONLINE
jms180
  • 1,462 Thanks
  • 1,538 posts
Posted July 02, 2016 - 01:33 PM
have you checked the throttle plate in the carburetor
#4 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted July 02, 2016 - 01:40 PM
Throttle plate is intact.
  • rustyoldjunk said thank you
#5 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted July 02, 2016 - 01:43 PM
Throttle cable wasn't hooked up when I brought it home. I have it hooked the way I think it should go(tried various ways) no matter what I do she goes wide open just as soon as I give it a little juice.
#6 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted July 02, 2016 - 03:07 PM
Just figured it out. When I got it home and started to work on it I knew I would have to clean the carb, when I took it apart the float was split. We took a carb off of another Briggs we had that I know is good and put it on, fired it right up. Well the throttle shaft on the good carb where the rod hooks is clocked about 2:00 and the shaft on the original carb is clocked about 8:00. Just got through putting the good float in the original carb and problem fixed!!!
#7 boyscout862 ONLINE
  • 12,518 Thanks
  • 9,028 posts
Posted July 02, 2016 - 04:03 PM
You can change the orientation by pulling the shaft out and turning it 180*. I've seen it before on the old 23D Briggs engines. Good Luck, Rick
#8 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted July 02, 2016 - 04:59 PM
Didn't think I would have much luck doing that. It was easier to just switch floats.
#9 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,605 Thanks
  • 1,306 posts
Posted July 06, 2016 - 08:58 PM
Post a picture of your throttle/governor spring setup. We can tell you if its right or what to fix.
EDIT: I should read the whole thread before I post. :D :smilewink:
On a side I have flipped a few butterflys over (including ones in Briggs carbs :poke: ) It works but the shaft is really only intended to go one way and is only threaded on one side for the two tiny screws that hold the butterfly to the shaft so it always makes me nervous but has always worked out well for me.
Edited by rustyoldjunk, July 06, 2016 - 09:09 PM.
  • powerstroker00 said thank you
