Help painting K161 engine
13 replies to this topic
#1 Manfjourde OFFLINE
Manfjourde
  • 118 Thanks
  • 180 posts
Posted July 02, 2016 - 10:22 AM
So it's time to do the engine. I am planning on a wire wheel. Do any of you have tips for a first timer so I don't make some dumb mistakes on removing the old, priming, and painting?
  • Bolens 1000 and alissanq60 have said thanks
#2 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted July 02, 2016 - 10:39 AM
Are you planning on stripping it down more or painting like that
They key to a good job is all in the prep work, use a good degreaser and make sure the surfaces are clean before priming, mask off anything you dont want paint on like the crank, seals ect.
  • boyscout862, HANKG and Manfjourde have said thanks
#3 Manfjourde OFFLINE
Manfjourde
  • 118 Thanks
  • 180 posts
Posted July 02, 2016 - 10:58 AM
I was going to just wire wheel the whole thing. Would I be better to use a degreaser on it first?
#4 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted July 02, 2016 - 11:11 AM
I would use degreaser first.
  • boyscout862 and Manfjourde have said thanks
#5 dodge trucker OFFLINE
dodge trucker
  • 2,435 Thanks
  • 3,123 posts
Posted July 02, 2016 - 12:44 PM
Id pull the tin off and check the back sides for rust, especially the main shroud. it will be a better job if you clean the block and tin that way. otherwise,  paint will ball up thick in the corners where parts butt together,  thick paint will peel more likely than thin.
  • HANKG and Manfjourde have said thanks
#6 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted July 02, 2016 - 05:31 PM
If you want to do it right I'd pull the tins off, any exposed metal and grease left behind there will bleed out onto your new paint overtime....
  • dodge trucker and Manfjourde have said thanks
#7 glgrumpy ONLINE
  • 8,609 Thanks
  • 7,920 posts
Posted July 03, 2016 - 08:11 AM
Um! Partial tear down, blast, prime (or not), paint pretty. Brushing wont do much.
#8 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,299 Thanks
  • 9,779 posts
Posted July 03, 2016 - 08:35 AM
A wire wheel isn't going to get into everything. Sand blasting is better. Put plugs in all the orifices first.
  • Manfjourde said thank you
#9 DougT OFFLINE
DougT
    Dog Approved
  • 6,926 Thanks
  • 4,994 posts
Posted July 03, 2016 - 09:51 AM
Never sand blast an engine together and expect to run it. No matter how well sealed you think it is, the sand will still find a way in there.
  • Bolens 1000 and Manfjourde have said thanks
#10 glgrumpy ONLINE
  • 8,609 Thanks
  • 7,920 posts
Posted July 03, 2016 - 11:10 AM
Blast tins and parts, wire brush case. Should have said, is way I do.
  • WHdbJD and Manfjourde have said thanks
#11 Trav1s ONLINE
Trav1s
  • 3,309 Thanks
  • 4,364 posts
Posted July 06, 2016 - 08:49 PM
yup
Degrease before the work.  Simple Green or Purple Power are my choice for step 1.
#12 Manfjourde OFFLINE
Manfjourde
  • 118 Thanks
  • 180 posts
Posted July 08, 2016 - 04:37 PM
Okay thanks all for the replies! Due to finances I'm going to degrease and wire the case and parts.
What do you all use for degreasing?
What do you use to cover holes and what not?
#13 KennyP OFFLINE
  • 38,337 Thanks
  • 45,913 posts
Posted July 08, 2016 - 05:11 PM
I like purple power.
#14 Manfjourde OFFLINE
Manfjourde
  • 118 Thanks
  • 180 posts
Posted July 09, 2016 - 08:37 AM
I have some. Do you scrub it, spray it and let it sit?
