For Sale
John Deere 314 w/ implements
1 reply to this topic
#1 easternharvest OFFLINE
easternharvest
  • 155 Thanks
  • 140 posts
Posted July 01, 2016 - 11:19 AM
You are looking at a 1982 John Deere 314 with hydrostatic transmission and all the implements to do whatever you need to on your property. This tractor is in excellent shape for its age. She has a 14 hp Kohler engine which has had the following replaced: battery, battery cables, solenoid, starter switch, 25 amp circuit breaker, points, condenser, spark plug, fuel filter, and air filter. This engine is solid no leaks or smoke. All fluids replaced this spring. The tires are in great shape, hold air with no leaks or cracks. The tractor has single front and mid hydraulics. Included in this package is the following: JD 314 tractor, cast wheel weights, mule drive, 46" triple blade cutting deck, 48" snow/dirt plow, integral sleeve hitch w/lift rod, 10 cubic ft cart, #7 JD cart, cultivator, double disk harrow, 10" moldboard plow, and 12" moldboard plow. You could search all season trying to put together a package like this (I know, I did). Let me save your time and gas. All this for $2250 obo.
Will also consider selling separately:
Tractor $1000
Wheel weights $200
Mule drive $100
Deck $100
Snow/Dirt plow $100
Integral sleeve hitch $200
10 cubic ft car $50
#7 JD cart $50
Cultivator $100
Double disk harrow $200
10" moldboard plow $100
Edited by easternharvest, July 01, 2016 - 11:48 AM.
  • limebuzz said thank you
#2 dropped82 ONLINE
dropped82
    Nut Case
  • 2,493 Thanks
  • 1,816 posts
Posted July 04, 2016 - 05:42 PM
Sent you a pm.
Eric
Sent from my SPH-L720T using Tapatalk
