3pt.lift arms
16 replies to this topic
#1 BowlBuilder OFFLINE
BowlBuilder
  • 492 Thanks
  • 473 posts
Posted July 01, 2016 - 10:27 AM
Recently obtained a 1614 with three point hitch. Unfortunately the two lift arms are incorrect. Any ideas where I might be able to purchase the Heim joint or rod end? Not sure of the correct name, but they are threaded 1/2-13 and adjust the arms individually via a knob on top. If I can just find the swivel, I can fab the rest up. Thank you very much.
#2 BowlBuilder OFFLINE
BowlBuilder
  • 492 Thanks
  • 473 posts
Of course a good used set at the right price would also work.
#3 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 150 posts
Posted July 01, 2016 - 10:34 AM
i have the whole three point off a 1617 if it will fit.
#4 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 01, 2016 - 10:55 AM
Check out the 3-pt hitch section of Xtrememotorworks.com --I'm not sure if the Cub ones will fit, but it's a start.
  • Eric said thank you
#5 BowlBuilder OFFLINE
BowlBuilder
  • 492 Thanks
  • 473 posts
Posted July 01, 2016 - 03:14 PM
The plastic tractors do have a different 3pt. But I thank you regardless. I will try the cub site thank you and if anyone else can provide any additional information it would be appreciated. Looking for new or used. If I could just obtain the threaded swiveling ball joint (Heim joint I believe) I can weld on the two studs no problem. Thank you.
#6 Rock farmer ONLINE
Rock farmer
  • 1,318 Thanks
  • 1,282 posts
Posted July 01, 2016 - 03:48 PM
Go to mscdirect.com
Search for spherical rod ends.
They offer 119 different sizes and styles.
You should be able to find what you need there.
Joe
#7 MNGB ONLINE
MNGB
  • 2,704 Thanks
  • 1,605 posts
Posted July 01, 2016 - 04:12 PM
Hi Bowl, what model yr is your PK can you post a picture of the 3 pt, as for finding the lift links e bay would be the place for used, Mission Mfg would have new, if you do find a source for the Heim units please let us know I for one would like to have one or 2 I've searched some and have come up with nothing yet but I haven't spent a lot of time looking.
#8 BowlBuilder OFFLINE
BowlBuilder
  • 492 Thanks
  • 473 posts
Posted July 01, 2016 - 04:25 PM
No dice. The inner swiveling ball portions are all smooth bore or have threads sticking out of them. I need ones that the swiveling ball itself is internally threaded. See picture. Has two studs welded to the sides. Shown immediately below the handle.
D62BE69E-8BAD-4346-B032-813D9FF4269E_zps
#9 MNGB ONLINE
MNGB
  • 2,704 Thanks
  • 1,605 posts
Posted July 01, 2016 - 04:29 PM
Hi Bowl I think your best bet is going to be e bay or a member that has one they will part with, like I posted I would like to find 1 or 2 also to convert my 76 to that style. or Mission for new ones
http://powerkingtractor.com/
#10 BowlBuilder OFFLINE
BowlBuilder
  • 492 Thanks
  • 473 posts
Posted July 01, 2016 - 04:53 PM
Thank you very much. Any idea what Mission charges for them? If I happen to find some used ones I'll pick you up a pair if more than one set is available.
#11 James Bosma ONLINE
James Bosma
  • 1,589 Thanks
  • 755 posts
Posted July 01, 2016 - 04:54 PM
Something like this
http://www.tscstores...px#.V3bmFY-cEeg
#12 BowlBuilder OFFLINE
BowlBuilder
  • 492 Thanks
  • 473 posts
Posted July 01, 2016 - 05:06 PM
No. The inner swiveling ball needs to have threads. This has a smooth bore. Thank you though.
#13 BowlBuilder OFFLINE
BowlBuilder
  • 492 Thanks
  • 473 posts
Posted July 01, 2016 - 05:09 PM
Notice how the swiveling ball has a threaded rod screwed through it for adjusting. The ball itself is threaded 1/2-13.
B8369D55-E867-41F9-804B-E490526382CE_zps
Edited by BowlBuilder, July 01, 2016 - 05:12 PM.
#14 BigFlash ONLINE
BigFlash
  • 248 Thanks
  • 134 posts
Posted July 01, 2016 - 06:28 PM
Weld a nut to a generic one? or weld a nut inside an oversized one? or buy a undersized one and cut threads into it?
I don't think your gonna find an end like that, that is threaded.
Edited by BigFlash, July 01, 2016 - 06:28 PM.
#15 Alc ONLINE
  • 7,357 Thanks
  • 7,638 posts
Posted July 01, 2016 - 09:14 PM
The ball isnt threaded , its welded to the threaded rod . It raises and lowers by the clevis , if it was threaded it wouldn't change as you turn it
  • shorty, Genem and MNGB have said thanks
