Figured out the best cell phone case
6 replies to this topic
#1 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,490 Thanks
  • 6,178 posts
Posted June 30, 2016 - 02:55 PM
Today I had an interesting job given to me.  Go to the mine, go to the overland belt drive, open up the top cover of a large gear reducer and fish out an iphone 6 plus that a guy had dropped in there awhile inspecting the gearing 2 days ago.  I went to lowes picked up one of those trash grabbers and see if I could snag it.
The inspection hole was about 10"x10".  This gear case holds 150 gallons of oil, is roughly 8 feet long 2 feet wide, and 6 feet tall.  We eventually drained the oil out, and found the phone.  After much messing around I was finally able to get ahold of it with the trash grabber.  It was a slippery son of a gun!
The phone was STILL ON.  Had 50% battery, screen worked, everything.  Picked it up and made a call on it.  Worked 100% perfect.
The case was a pelican.  The phone spent over 48 hours completely submerged in 320 synthetic gear oil.  Phone as far as I can tell has no problems.  Speakers work, touch screen works, screen is clear as it ever way.
http://www.pelican.c...phone-6-and-6s/  Marine model.
I highly recommend it.
  • MH81, Alc, KennyP and 4 others have said thanks
#2 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted June 30, 2016 - 03:00 PM
Oil being thicker than water probably saved it as it can't get in through the smaller gaps without more pressure. Still a great case anyhow.
  • boyscout862, toomanytoys84 and chieffan have said thanks
#3 chieffan ONLINE
  • 10,883 Thanks
  • 6,916 posts
Posted June 30, 2016 - 03:10 PM
And just how much does it cost for the honor to own an oil proof cell phone? ?
  • KennyP and toomanytoys84 have said thanks
#4 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,490 Thanks
  • 6,178 posts
Posted June 30, 2016 - 03:14 PM
Not sure what it costs. I just don't drop mine in oil filled gear cases
Sent from my XT1254 using Tapatalk
#5 Bill 76 OFFLINE
Bill 76
  • 2,001 Thanks
  • 1,204 posts
Posted June 30, 2016 - 03:25 PM
I'll bet a lot less  then the manpower labor and machine downtime to recover said phone.
#6 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,490 Thanks
  • 6,178 posts
Posted June 30, 2016 - 05:24 PM
Downtime wasn't an issue. This belt is idle for a couple days. If it was down for 8 hours because of this it would of been $440,000. That's 10,000 tons of coal production lost at $44 dollars a ton.
3400 labor(5 people 8 hours) 85 an hour is the general purpose labor rate for when our group has to be in the field.
800 for 150 gallons of synthetic gear lube
4200 to retrieve the phone.
The phone wasn't retrieved for the owner but because we didn't want it to get picked up and smashed into the gearing.
  • Bill 76 said thank you
#7 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,490 Thanks
  • 6,178 posts
Posted June 30, 2016 - 05:25 PM
You are probably right. But I am still impressed by the performance of this case!
I usually by otter boxes just because it offers some protection.
