QT/S series tiller Shaft question
4 replies to this topic
#1 Husky OFFLINE
Husky
  • 1508 Thanks
  • 1202 posts
Posted June 29, 2016 - 11:44 AM
I think that the QT/S series tiller shaft will fit on a large frame correct? I believe that the difference is the length of the tiller shaft? Thank you for any thoughts on this.
#2 Paulgo OFFLINE
Paulgo
  • 757 Thanks
  • 481 posts
Posted June 29, 2016 - 01:05 PM
Q series shaft is about 1/2" shorter over all than the one for my HT23. Both have 15 tooth couplers.  Paul
  • Husky said thank you
#3 Husky OFFLINE
Husky
  • 1508 Thanks
  • 1202 posts
Posted June 30, 2016 - 06:24 AM
Thank you Paul. With that said a telescoping shaft on a large frame should work fine on a Q series with a tiller as it is missing the drive shaft.
#4 Paulgo OFFLINE
Paulgo
  • 757 Thanks
  • 481 posts
Posted June 30, 2016 - 10:14 AM
I've never seen a two piece tiller shaft, but like the concept. Would have to be fastened at both ends, rather than floating at the tiller end, right?  Paul
#5 Husky OFFLINE
Husky
  • 1508 Thanks
  • 1202 posts
Posted June 30, 2016 - 10:53 AM
Hi Paul,
Yes, the end to the pto has the factory quick connect on it. The other end has two set screws and works quite well. It was built and balanced I did not manufacture this one myself.
  • Paulgo said thank you
