Grass edger for concrete
2 replies to this topic
#1 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted June 29, 2016 - 12:37 AM
got this little Machine  last weekend PB090009.JPG it is a Scott-Bonnar lawn edger
this is the cutter side of it in principle same as a mower cutter  about 3 to 3.5 HP maybe
it has good compression  but missing the air filter parts which i should have some place around
It is an odd 1 as it's got the 6 wheels not 3 , so a early type , has a plate but got to see if it's readable
will be keeping this 1 but for whaT REASON i don't know  , maybe a trim saw for rough cutting thin wood
Shane
  • DougT, Alc, CRFarnsworth and 3 others have said thanks
#2 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted June 29, 2016 - 08:23 AM
It is interesting but, I hope that you don't plan to use it. It looks very dangerous to me. I would not trust the pivot nor the shield. Good Luck, Rick
Edited by boyscout862, June 29, 2016 - 08:23 AM.
#3 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted June 30, 2016 - 10:21 PM
it was manufactured like that so must be safe to a degree lol , they are still made here but in smaller & tidier versions petrol & electric types ,
i had the idea of mounting it on rails & changing the cutter to a saw blade to use rough cutting small timber maybe , just an idea
Shane
