Cub Cadet Driveshaft Lengthening
3 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted June 28, 2016 - 10:43 PM
Have a project that I want to do, and I need advice from the pulling guys. I am going to stretch my Cub Cadet 102 either 14" or 16" to build a utility type machine with small dump bed. The question I have regards the driveshaft lengthening. I have several ideas, and am wondering if the simplest is the best. Use 1" DOM tubing with .1875" wall (0.625" ID) overlapping some of the original driveshaft and going all the way to the transaxle with said tubing and drilling for the rollpins. Concern is always alignment and wobble, and I could add a support bearing just like most serious pullers do to combat those issues. So does anyone see an issue with this method, or should I do something with universal joints, ragjoints, or lovejoy couplings?
Thanks.
#2 dodge trucker ONLINE
dodge trucker
  • 2,432 Thanks
  • 3,122 posts
Posted June 29, 2016 - 06:19 AM
those are not hard to make, find a piece of "stress proof" rod and cut to length desired then drill holes for roll pins, done. I would definitely add a pillow block bearing where convenient  to help it spin true and avoid vibration.
I have seen lots of Cub Cadets stretched to make something like you are talking about, usually they are made into something like a 2 or 4 person butt buggy with a canopy top.
  • wvbuzzmaster said thank you
#3 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted June 30, 2016 - 10:48 PM
On my my pullers i use usually stainless steel rod and make my own coupler to connect the input shaft. I use a pillow blocks on all of them as well seeing that all the stress is mainly on the drivetrain itself.
  • Alc and wvbuzzmaster have said thanks
#4 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted July 10, 2016 - 07:25 AM
Very strong 4130 chrome molly .625 light weigh and hi strength with center bearing
