Brinly cultivator converted to tow behind?
8 replies to this topic
#1 Greasy6020 OFFLINE
Greasy6020
  • 1,477 Thanks
  • 1,399 posts
Posted June 28, 2016 - 09:39 PM
Has anyone ever done this???
I would like to convert my brinly cultivator over to tow behind so I can avoid the whole sleeve hitch deal...
Anyone have the usual good ideas?
  • chieffan said thank you
#2 chieffan ONLINE
  • 10,174 Thanks
  • 6,650 posts
Posted June 28, 2016 - 10:28 PM
How will you raise and lower it if you bypassing the sleeve hitch??
  • Greasy6020 said thank you
#3 MH81 OFFLINE
Posted June 28, 2016 - 10:57 PM
Can be done, but why?
Bolt on a pair of runners 2" up (or wheels) should work
You'll fight to get your pull geometry right, then it will change with changing soil conditions
Dryness rocks Etc
What is prohibiting you from hooking it up with a sleeve hitch?
#4 Greasy6020 OFFLINE
Greasy6020
  • 1,477 Thanks
  • 1,399 posts
Posted June 28, 2016 - 11:10 PM
No sleeve hitch tractors to be found, the cost of a sleeve hitch assembly is very prohibitive. Cost for a john deere sleeve hitch for my 300 is nearly what I payed for the tractor...
#5 MH81 OFFLINE
Posted June 28, 2016 - 11:11 PM
Building one out of the question?
#6 Greasy6020 OFFLINE
Greasy6020
  • 1,477 Thanks
  • 1,399 posts
Posted June 28, 2016 - 11:15 PM
i might be able to build one in shop class next semester, I am friends with the auto shop teacher...
#7 MH81 OFFLINE
Posted June 28, 2016 - 11:18 PM
Around here, you can find a set of drag harrows (old horse pulled units) easier than you would think.
#8 Alc OFFLINE
  • 6,887 Thanks
  • 7,461 posts
Posted June 29, 2016 - 05:30 AM
If you could find an old DB cultivator you could either use it or take the wheels along with the adjusters & bar  ( the whole rear bar adjusts to width ) and bolt it on this way you could tow it , set the depth and when your ever get a sleeve hitch you .  Here's a picture of mine , this one wouldn't be as handy because it's the crank adjust type , all my others have notches to adjust
  • MH81, holdenboy1960 and Greasy6020 have said thanks
#9 Mgking OFFLINE
Mgking
  • 24 Thanks
  • 16 posts
Posted June 29, 2016 - 10:26 AM
Iv got a home made sleeve hitch id sell. i used it on my 314 and 317.  all you would have to make then is a lift bar.  or use ur tiller bar if u have one.  id do 75 plus some shipping.  five one five five three eight zero one eight six is my cell.  Im in northern iowa.  let me know if your interested.
  • Alc and Greasy6020 have said thanks
